查看: 18672|回复: 5
[推荐] moldex3d R9 SP3 升级信息
发表于 2008-9-26 11:17:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Bug Fixes
1. Solvers
    1.1  [3DFlow]Fail to write EOF results to m3o file.(8451)[Special]
    1.2  [3DFlow]The grammar is incorrect.(8556)[General]
    1.3  [Flow]Unable to read results on some sensor nodes inside cavity when
        analyzing an eDesign model.(8434)[General]
    1.4  [3DWarp]Rigid body moving occurs in warpage analysis when using
        solver acceleration(8525)[General]
    1.5  [3DCool]after read flow result, the average part temperature history not
        smooth.(8549)[General]
    1.6  [3DFastCoolE]Parallel computing will be failed with cooling network
        analysis.(9047)[General]
    1.7  [3DFastCoolE]Can’t execute fastcool enhance in parallel
        computation.(8594)[General]
    1.8  [3DOptics]Spell wrong words in lgo file.(8763)[General]
2. Pre-processor
    2.1  [Designer] Designer always Shows Free edge which case has no free
        edge (checked by Rhin Mesh) (8086)[General].
    2.2  [Designer]Fail to set characteristic length in the segment properties by
        left key double click when creating sold mesh.(8324)[General]
    2.3  [Designer](9065.2)the runner layout of the user designed whill be
        changed when generating solid mesh.(8639)[General]
    2.4  [Designer]the warning msg of cooling channels is
        unreasonable.(8973)[Internal]
3. Post-processor
    3.1  [Project] Projectshould not check Solid-Project existed in eDesign
         license mode only(8165) [General].
    3.2  [Project] Project can't identify the check-outed VE/Optics
         licenses(8172)[General].
    3.3  [Project] Crash when exporting the data of ABAQUS that users have
         I2-ABAQUS license only (8191)[General].
    3.4  [Project] Output file of output mesh as deformed in NENastran is
         incorrect (8293)[General].
    3.5  [Project]The characters displayed in project and curve title are random
        code Japan OS.(8341)[General]
    3.6  [Project]mde file not support weld line and air trap, but can select in
         model manager(8470).[General]
    3.7  [Project]The volume is not correct in symmetry case.(8228)[General]
    3.8  [Project]The symmetry surfaces are always shown on the
        screen(8227)[General]
    3.9  [Project]Project export PRO file under Vista with Read only error
         message for Desktop folder.(7407)[General]
   3.10 [Project]Wrong word in material reduction of I2.(8433)[General]
   3.11 [Project]The project always shows an none meaning dialog to say the
        auto loading has turned off.(7676)[General]
   3.12 [Project]The multiple time steps output setting is not
        consistent.(8840)[General]
   3.13 [Process] The saved value of transfer and cure pressure will change
        after creating a new run.(8290)[General].
   3.14 [Process]Show error msg when import another pro file which mesh file
         name is different from original. (8410) [Special]
   3.15 [Process]when set up the the mold temperature by using profile polyline,
        the chart does not follow profile setting.(8507)[General]
   3.16 [Process]The time of Bounary Condition does not follow filling time and
         packing time.(8508)[General]
   3.17 [Process] Cannot set BC profile to Polyline mode.(8521)[General]
   3.18 [Material] Selecting a specific material in the "Find Material function"
         leads crash (7991)[Special].
   3.19 [Material] RIM-mechanical properties mismatching in filling log files
         (7594)[General].
3.20 [Material]Unit Temperature[oC] symbol gone in Spain
         OS(8333)[General]
    3.21 [Material]Can't set material in IC Package from user
         bank.(8672)[General]
    3.22 [Material]Material will crash when create a new Material to Material Bank
         in CHT version.(8955)[General]
    3.23 [AutoProcess] Crash with the shell model case on Vistax64
         (8287)[General].
发表于 2008-9-26 12:15:05 | 只看该作者
发表于 2008-9-26 19:13:19 | 只看该作者
发表于 2008-10-26 12:02:56 | 只看该作者
发表于 2009-8-26 19:29:04 | 只看该作者
发表于 2010-12-10 11:03:19 | 只看该作者
GMT+8, 2026-8-12 08:28 , Processed in 0.059146 second(s), 10 queries , Gzip On, Redis On.
