查看: 16977|回复: 1
[分享] ugnx支持双核CPU
发表于 2008-10-5 11:29:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
https://hi.baidu.com/lee8888/blog/item/d47c220132d06b05728da522.html
网上看到的,用NX的朋友,如果是双核CPU可以试一下!
ug支持双核2008-09-14 03:10This variable enables Symmetric Multi-processing (SMP)
on systems
# with multiple CPU's or that support hyperthreading. Performance will
# be improved in certain Parasolid operations, such as Mass Properties,
# Booleans and silhouette generation. This option is only supported on
# platforms where Parasolid supports multi-threading.
# Set to 0 to disable SMP
# Set to 1 to enable SMP
UGII_SMP_ENABLE = 1
修改ugii文件夹里的ugii_env.dat,用记事本打开,寻找smp项
hide因为在tcl语言里#之后都是解释项,# UGII_SMP_ENABLE = 1这句就相当于把功能屏蔽了
,所以只要将#号去掉就能发挥双核性能了
[ 本帖最后由 changqingfeng 于 2008-10-8 09:17 编辑 ]
发表于 2008-10-5 23:32:02 | 只看该作者
GMT+8, 2026-8-18 02:55 , Processed in 0.070477 second(s), 11 queries , Gzip On, Redis On.
