查看: 15724|回复: 1
[原创] 就添加了一个建方块的的函数,不知道为什么报错
发表于 2008-10-20 12:39:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我就添加了一个建方块的的函数,不知道为什么报错 请高手们看下
b.h  代码如下:
** b.h
** Description:
**    b header file.
static void PrintErrorMessage( int errorCode );
static void do_ugOPEN_api(void)
b.cpp代码如下:
//  b.cpp
//  Description:
//      Contains Unigraphics entry points for the application.
//  Include files
#include <uf.h>
#include <uf_exit.h>
#include <uf_ui.h>
#if ! defined ( __hp9000s800 ) && ! defined ( __sgi ) && ! defined ( __sun )
# include <strstream>
#   include <iostream>
using std:strstream;
using std::endl;
using std::ends;
using std::cerr;
#else
# include <strstream.h>
#   include <iostream.h>
#endif
#include "b.h"
//  Activation Methods
//  Unigraphics Startup
//      This entry point activates the application at Unigraphics startup
extern "C" DllExport void ufsta( char *param, int *returnCode, int rlen )
    /* Initialize the API environment */
    int errorCode = UF_initialize();
    if ( 0 == errorCode )
        /* TODO: Add your application code here */
         do_ugOPEN_api();
        /* Terminate the API environment */
        errorCode = UF_terminate();
    /* Print out any error messages */
    PrintErrorMessage( errorCode );
//  Utilities
// Unload Handler
//     This function specifies when to unload your application from Unigraphics.
//     If your application registers a callback (from a MenuScript item or a
//     User Defined Object for example), this function MUST return
//     "UF_UNLOAD_UG_TERMINATE".
extern "C" int ufusr_ask_unload( void )
    return( UF_UNLOAD_UG_TERMINATE );
/* PrintErrorMessage
**     Prints error messages to standard error and the Unigraphics status
**     line. */
    if ( 0 != errorCode )
        /* Retrieve the associated error message */
        char message[133];
        UF_get_fail_message( errorCode, message );
        /* Print out the message */
        UF_UI_set_status( message );
        // Construct a buffer to hold the text.
        ostrstream error_message;
        // Initialize the buffer with the required text.
        error_message << endl
                      << "Error:" << endl
                      << message
                      << endl << endl << ends;
     // Write the message to standard error
        cerr << error_message.str();
   UF_FEATURE_SIGN sign=UF_NULLSIGN;
   UF_FEATURE_SIGN sign1=UF_POSITIVE;
   double block_orig[3]={0.0,0.0,0.0};
   double block_orig1[3]={0.0,0.0,2.5};
   char *block_len[3]={"1","2","3"};
   char *block_len1[3]={"1","2","3"};
   tag_t blk_obj;
   tag_t blk1_obj;
   int i_ret;
   i_ret=UF_MODL_creat_block1(sign,block_orig,block_len,&blk_obj);
   i_ret=UF_UI_OPEN_listing_windows();
   if(i_ret==0)
   UF_UI_write_listing_windows("成功创建block\n");
   else
   UF_UI_write_listing_windows("创建block失败\n");
   return;
   i_ret=UF_MODL_creat_block1(sign1,block_orig1,block_len1,&blk1_obj);
   if(i_ret==0)
   else
   return;
发表于 2008-10-24 09:46:16 | 只看该作者
报什么错啊?你不说清楚问题,人家怎么帮你看啊
GMT+8, 2026-4-30 06:00 , Processed in 0.052618 second(s), 11 queries , Gzip On, Redis On.
