查看: 16807|回复: 3
[求助] Can anyone tell me how to make this chair
发表于 2008-11-19 03:01:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Sorry guys,i can not type chinese from my pc right now,can anyone tell me how to make the chair in Rhino please? To make it clear to you how the chair actually look like, i upload two images from different viewpoints. Thanks a lot.
Bu hao yi si, wo dian nao huai le,bu neng da zhong wen, qing wen da jia neng fou gao su xiao di wo ru he zuo zhe ge yi zi? wei le rang da jia kan qing chu,wo fa le liang zhang bu tong jiao du de..
jing hou jia yin,xie xie da jia
发表于 2008-11-19 03:09:12 | 只看该作者
tong guo peng you zhi dao zhe li you hen duo re qing de gao shou, suo yi te yi zhu ce lai qing jiao ge wei, ma fan ge wei gao shou gei xie si lu,xiao di gang xue rhino, hai hen ben,qing ge wei gao shou duo duo ci jiao
发表于 2008-11-19 03:16:15 | 只看该作者
nong le ji tian ye mei nong chu lai,bei bie zhu de gan jue hen nan shou...jiu ming a
发表于 2008-11-20 07:34:57 | 只看该作者
来个简单的示范,形不是很准
1 Draw Curves
2 loft surface
3 blend curve
4 trim surface by curve
5 offset surface
6 blend surface
7 join all surface
GMT+8, 2026-6-20 12:05 , Processed in 0.056883 second(s), 13 queries , Gzip On, Redis On.
