查看: 15884|回复: 1
[求助] 曲线的光顺??
发表于 2008-12-16 21:12:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
函数UF_CURVE_smooth_spline_data中的第2、3、4个参数分别是什么意思(参数是cont_order、distance_toler、angle_toler)??还望高手指点!!
发表于 2008-12-16 22:33:25 | 只看该作者
自己补充一下!
在ug帮助文档中,其中cont_order意思是:order of continuity to achieve。
                     distance_toler是:tolerance; smoothing is done if the deviation in shape introduced is less than this amout. Zero indicates use NX modelling resolution.
   angle_toler是tolerance; smoothing is done if the angle between tangents at the joint is less than this amount. Zero indicates use NX modelling resolution.
可是不知道意思!!
GMT+8, 2026-6-29 06:22 , Processed in 0.079934 second(s), 11 queries , Gzip On, Redis On.
