查看: 16516|回复: 0
[原创] About Downward Compatibility in Catia
发表于 2008-12-18 23:27:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
if someone has trouble with downward compatibility of CATIA, the following might be the solution to get it work.
open an MS-DOS window,
go to C:\CAD\catia\B17\intel_a\code\bin,
please input the following,
CNEXT -batch -e CATUIDownwardCompatiblity.
later the CATIA V5 Downward Compatibility window opens,convert what you want.
also under the tab of licensing in option, please check the licenses as many as possible.
restart your catia, then you must be able to run that function in utility under tools in catia, not only from command line.
GMT+8, 2026-8-18 11:48 , Processed in 0.041178 second(s), 11 queries , Gzip On, Redis On.
