查看: 18605|回复: 0
[原创] 求救!UF_MTX3_rotate_about_axis
发表于 2009-2-8 20:50:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
void Make_Rister_Matrix_9(double rister_o[3],CString rister_z,double matrix_values[9],CString m_kc,
                                                  double new_matrix_values[9],double output_point[ 3 ] )
        double rotation_angle;
        double rotation_axis[ 3 ];
        double rister_c[3];
        tag_t  matrix_id;
        tag_t  wcs_id;
        tag_t csys_id;
        UF_CSYS_ask_wcs (&wcs_id );
        UF_CSYS_create_matrix (matrix_values, &matrix_id );
        UF_CSYS_create_csys (rister_o, matrix_id, &csys_id );
        UF_CSYS_set_wcs (csys_id);
        UF_CSYS_set_wcs_display (1);
        rotation_angle = atof(m_kc)*DEGRA;
        rister_c[0] = 0.0;
        rister_c[1] = 0.0;
        rister_c[2] = atof(rister_z);
        UF_CSYS_map_point (UF_CSYS_ROOT_WCS_COORDS, rister_c,
                UF_CSYS_ROOT_COORDS, output_point);
        UF_MTX3_z_vec (matrix_values, rotation_axis);
        rotation_axis[2] = 0.0-rotation_axis[2];
        UF_MTX3_rotate_about_axis (rotation_axis, rotation_angle, new_matrix_values);
        UF_MTX3_y_vec (matrix_values, rotation_axis);
        UF_CSYS_set_wcs(wcs_id);
        UF_OBJ_delete_object(csys_id);
UF_MTX3_rotate_about_axis:结果是绝对坐标下的matrix,该怎么得到在新建的
坐标下旋转后的matrix 啊???
GMT+8, 2026-4-29 21:29 , Processed in 0.116415 second(s), 11 queries , Gzip On, Redis On.
