查看: 16383|回复: 0
[求助] 2005R2版的设置问题
发表于 2009-2-13 20:06:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1) unRAR to a place of your choice
2) copy "\ZWT\2005r2\" dir into your Windows Install dir,这是什么意思?windows的安装目录还是adams的安装目录,都试过了也不行
3) run "keygen.exe" from "\ZWT" dir to generate a valid license
4) run "\ZWT\FlexLM\setup.exe" to setup the license server,
    use the generated license from step 3
5) open the "msCADams252.reg" and do a search & replace
   for [REPLACE], replase it with your install dir but
    make sure to use double \\
eg.: Install dir: C:\Program Files\MSC\Adams
                -> C:\\Program Files\\MSC\\Adams
*NOTE* You need to do a manual replace for the following line:
!!! REPLACE !!! "STopdir"="c:\\MSCSOF~1.200\\"
Its a 8.3 dir format
                -> C:\\Progra~1\\MSC\\Adams
The old DOS shit ;-)
6) you are done now, run the apps of your choice,
    to get the infos to create shortcuts, check "mscadams252.reg",这个快捷方式到底怎么做?我觉得很大可能是这里没做对,其他应该都做对了。
7) enjoy another fine ZWT-release!
GMT+8, 2026-8-2 15:33 , Processed in 0.047695 second(s), 10 queries , Gzip On, Redis On.
