查看: 21060|回复: 3
[求助] adams/car 仿真失败, 请高人指点
发表于 2009-2-19 21:16:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用adams/car做整车仿真, 模型用的是adams自带的, 仿真时出现如下Message:
Reading in property files...
Reading of property files completed.
Setting up the vehicle assembly for Driving Machine maneuver...
Setup of vehicle assembly completed.
Simulation is beginning...
Starting analysis #1 of vehicle assembly...
   *                      MSC.Software Corporation                     *
   *                             A d a m s                             *
   *          Automatic Dynamic Analysis of Mechanical Systems         *
   *                      A d a m s / S o l v e r                      *
   *      2009-02-17 17:24:21              Version MD R2               *
   *      Customer Entitlement ID:         -752D4EF5                   *
   Enter ADAMS model file name or Carriage Return or ? (or STOP):
   No model input file (ADM file) is given.
   Enter Command:
   file/model=workshop1a_ilc
   A new model supplied.  Initialization starts...
   The default input and analysis values will be restored.
   CPU time used = 7.81250E-02 seconds
   Enter ADAMS output file name or ? (default is same as input):
     Adams model file .. workshop1a_ilc.adm
   Default file names for output files
     Tabular output file:
     workshop1a_ilc.out
     Diagnostic file    :
     workshop1a_ilc.msg
     Message Database file    :
     workshop1a_ilc.mdb
     Graphics file      :
     workshop1a_ilc.gra
     Request file       :
     workshop1a_ilc.req
     Results file       :
     workshop1a_ilc.res
   Input Phase - Reading in Model
   Adams/Solver dataset Title:
   Adams/Car Assembly (MD R2 Adams)
ERROR:  Found an unexpected token while looking for a comma or end of statement.
ERROR:     Statement           : SPLINE
ERROR:     Argument            : Y
ERROR:     Value number        : 1
ERROR:     Statement at line   : 9186
ERROR:     Error at line       : 9188
ERROR:     Error line text     : ', Y = 1.[[#]]QNAN, 1.#QNAN, 1.#QNAN, 1.#QNAN, 1.#QNAN, 1.#QNAN, 1.#QNAN, 1.#QNAN'
ERROR:     Error token text    : '#'
ERROR:     Error token type    : unknown character
ERROR:  Errors in the Adams dataset prevent it from being loaded into the database.
   Reading of model complete.
   Adams/Car MD R2 Adams
Processing ENVIRONMENT entries in 'D:\ADAMS2007R2\Adams\MDR2\acar/acar.cfg'
Processing ENVIRONMENT entries in 'C:\Documents and Settings\Acer/.acar.cfg'
ERROR:  There is no corresponding object for this lookup index.
ERROR:     Error type:  ae_lookup_object_index
   Input Phase - Populating Solver database
---- ERROR ----
   Error(s) found in input, no model available.
   Input Phase Complete.
   CPU time is 0.20312 seconds.
---- ERROR ----
   An error has been found in the model dataset supplied
   through the FILE/MODEL command.  Dataset file name is:
   workshop1a_ilc.adm
   Enter Command:
   string/3, string=workshop1a_ilc.xml
---- ERROR ----
   STRING/3 has not been defined in the input data.
   Enter Command:
   preferences/solver=F77
   Enter Command:
   output/nosep
   Enter Command:
   control/ routine=abgVDM::EventInit, function=user(3,1,9,0,2,7,7,16)
---- ERROR ----
   No model is present in memory at this instant.
   Read in an Adams/Solver data set first.
   Enter Command:
   control/ routine=abgVDM::EventRunAll, function=user(0)
---- ERROR ----
   Enter Command:
   Enter Command:
   stop
   Terminating Adams/Car usersubs...
   Adams/Solver execution terminated by subprogram A3TERM
   CPU time used = 0.21875 seconds
ERROR: Cannot load results!  File 'workshop1a_ilc.res' not found.
ERROR: Cannot load graphics!  File 'workshop1a_ilc.gra' not found.
Simulation is complete.
请高人指点原因及解决方法!
发表于 2009-2-21 14:56:31 | 只看该作者
发表于 2009-3-1 16:13:54 | 只看该作者
发表于 2009-3-4 13:52:37 | 只看该作者
GMT+8, 2026-8-2 17:26 , Processed in 0.057036 second(s), 13 queries , Gzip On, Redis On.
