查看: 16441|回复: 8
[求助] 高手们帮偶看看这个UG API程序吧~~~ 感激涕零啊~~~
发表于 2009-2-27 20:19:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本人刚开始接触UG开发,想要绘制一条螺旋线,程序编译通过,可到UG里运行之后,却没有生成任何曲线,请各位高手大侠们帮偶看看吧~~~
本人不胜感激!!!
static void do_my_Program(double PARA[])
    int i;
    double my_dLead = PARA[0];                                   // 螺距
    double my_dRad = PARA[1];                                    // 半径
    double my_dZhuanNumber = PARA[2];                    // 圈数
    // 放置位置
    double luowen_orig[3];
    luowen_orig[0] = PARA[3];
    luowen_orig[1] = PARA[4];
    luowen_orig[2] = PARA[5];
     CString str[3];
    for (i=0 ; i<3 ; i++)
        str.Format("%f", PARA);
    char *LEAD = (char*)(LPCTSTR)str[0];                                        // 螺距
    char *RAD = (char*)(LPCTSTR)str[1];                                            // 半径
    char *numbers = (char*)(LPCTSTR)str[2];                                        // 转数
    double direction_cyl[3];                                                    // 矢量方向
    direction_cyl[0] = 0.0;
    direction_cyl[1] = 0.0;
    direction_cyl[2] = 1.0;
    int rec;
    int degree = 3;        // 样条次数
    int periodicity = 1;                                                           // 0:非周期样条 1:周期样条
    int save_def_data = 1;                                                   // 1则和创建的样条曲线一起保持输入数据,否则不保持
    tag_t spline_tag;                                                            // 创建的样条曲线指针——输出
    double start_pt[3], end_pt[3];
    // 起点坐标
        start_pt = luowen_orig;
    start_pt[0] += my_dRad;
    // 终点坐标
    double min_num, integer;
    double tem_pt[3];                                                            // 上端面中心点
        tem_pt = luowen_orig;
    tem_pt[2] += PARA[0]*PARA[2];
    min_num = modf(my_dZhuanNumber, &integer);
    get_another_point(tem_pt, my_dRad, min_num, end_pt);
    // 中间控制点
    int all_ctrlpt_numbers;
    int tem_ctrlpt;        // 一个导程的中间控制点数
    get_ctrlpt_number(my_dRad, tem_ctrlpt);
    all_ctrlpt_numbers = integer * tem_ctrlpt + (int)(360*min_num/(360/tem_ctrlpt));        // 中控点的总个数
    double **ctrl_pts;
    ctrl_pts =(double **)malloc((2+all_ctrlpt_numbers)*sizeof(double *));
    for(i=0 ; i<(2+all_ctrlpt_numbers) ; i++)
        ctrl_pts=(double *)malloc(sizeof(double)*3);
    //double ctrl_pts[all_ctrlpt_numbers][3];
    getData_ctrl_Pts(luowen_orig, 2+all_ctrlpt_numbers, my_dRad, my_dLead, ctrl_pts, start_pt, end_pt);
    // 参数定义
    int num_points = all_ctrlpt_numbers + 2;                                                        // (所有控制点的数目=起控点+中控点+终控点)point_data[]数组中点和参数的数目
    //UF_CURVE_pt_slope_crvatr_t point_data[all_ctrlpt_numbers];                                    // 定义样条上的点和斜率控制的数组
    UF_CURVE_pt_slope_crvatr_t *point_data;
    point_data = (UF_CURVE_pt_slope_crvatr_t *)malloc(num_points*sizeof(UF_CURVE_pt_slope_crvatr_t));
    double *slopeVecs;
    slopeVecs = (double *)malloc(num_points*sizeof(double));
    get_slope_point(luowen_orig, num_points, my_dRad, my_dLead, slopeVecs);
    double *crvatrVecs;
    crvatrVecs = (double *)malloc(num_points*sizeof(double));
    get_crvatr_point(luowen_orig, num_points, my_dRad, my_dLead, crvatrVecs);
    for (i= 0;   i<num_points;   i++)
        point_data.point[0] = ctrl_pts[0];
        point_data.point[1] = ctrl_pts[1];
        point_data.point[2] = ctrl_pts[2];
        point_data.slope_type = UF_CURVE_SLOPE_AUTO;
        point_data.slope[0] = slopeVecs[3*i];
        point_data.slope[1] = slopeVecs[3*i+1];
        point_data.slope[2] = slopeVecs[3*i+2];
        point_data.crvatr_type = UF_CURVE_CRVATR_NONE;
        point_data.crvatr[0] = crvatrVecs[3*i];
        point_data.crvatr[1] = crvatrVecs[3*i+1];
        point_data.crvatr[2] = crvatrVecs[3*i+2];
    // 节点
    double *parameters;                                                    // 输入点参数
    parameters = (double *)malloc((num_points + 4)*sizeof(double));
    getData_node(degree, num_points, parameters);
    rec = UF_CURVE_create_spline_thru_pts(degree, periodicity, num_points, point_data, parameters, save_def_data, &spline_tag);
    for(i=0 ; i<all_ctrlpt_numbers ; i++)
        free(ctrl_pts);
    free(ctrl_pts);
    free(point_data);
    free(parameters);
    free(slopeVecs);
    free(crvatrVecs);
// 已知半径和圈数,求旋转后点的XY坐标
static void get_another_point(double pt[], double rad, double angle, double new_point[3])
     double radian = angle * 2*PI;
    new_point[0] = rad*cos(radian) + pt[0];
    new_point[1] = rad*sin(radian) + pt[1];
    new_point[2] = pt[2];
// 由螺旋线半径确定一个导程里的中间控制点数目
static void get_ctrlpt_number(double rad, int &ctrlpt_number)
    if (rad>=1 && rad<15)
        ctrlpt_number = 8;
    else
        if (rad>=15 && rad<205)
            ctrlpt_number = 16;
        else
            if (rad>=205 && rad<3285)
                ctrlpt_number = 32;
            else
                ctrlpt_number = 64;
// 由放置点、控点个数、半径、导程,确定各个中控点坐标
static void getData_ctrl_Pts(double org_pt[3], int pt_number, double rad, double lead, double **ctrl_pts, double stpoint[3], double edpoint[3])
    double angle;
    double tem_pt[3], tem_ctrlPt[3];
    int i, j;
        tem_pt = org_pt;
    int tem_ctrlpt_num;                                                        // 一个导程中的控制点数
    get_ctrlpt_number(rad, tem_ctrlpt_num);
    double length_add_perPt = lead/tem_ctrlpt_num;                            // 每增加一个控制点,在Z方向上的增量
    for (i=0 ; i<pt_number; i++)
        if (i==0 || i==pt_number-1)
            if (i==0)
                for (j=0 ; j<3 ; j++)
                    ctrl_pts[j] = stpoint[j];
            else
                    ctrl_pts[j] = edpoint[j];
        else
            tem_pt[2] += length_add_perPt;
            angle = i/(double)tem_ctrlpt_num;
            get_another_point(tem_pt, rad, angle, tem_ctrlPt);
                ctrl_pts[j] = tem_ctrlPt[j];
// 由阶数和控制点数目,获得节点
static void getData_node(int degree, int ctrl_number, double *DATA_node_number)
    // 总节点数
    int node_number = ctrl_number + 8 - degree;
    int i;
    for (i=0 ; i<node_number ; i++)
        if (i<4)
            DATA_node_number = 0;
        else
            if (i<(ctrl_number+4-degree))
                DATA_node_number = (ctrl_number-degree-3)/(double)(ctrl_number-degree+1);
            else
                DATA_node_number = 1;
// 获得曲线上一点的斜率
static void get_slope_point(double org_pt[3], int pt_number, double rad, double lead, double *slope_pts)
    double angle;
    double radian;
    int i, j;
        tem_pt = org_pt;
        tem_pt[2] = tem_pt[2] + i*length_add_perPt;
        radian = angle * 2 * PI;
        tem_ctrlPt[0] = -rad*sin(radian);
        tem_ctrlPt[1] = rad*cos(radian);
        tem_ctrlPt[2] = lead/2/PI;
            slope_pts[3*i+j] = tem_ctrlPt[j];
// 获得曲线上一点的曲率
static void get_crvatr_point(double org_pt[3], int pt_number, double rad, double lead, double *crvatrVecs)
    double angle;
    double radian;
    int i, j;
        tem_pt = org_pt;
        tem_pt[2] += i*length_add_perPt;
        // 转数转化成弧度
        tem_ctrlPt[0] = -rad*cos(radian);
        tem_ctrlPt[1] = -rad*sin(radian);
        tem_ctrlPt[2] = 0;
            crvatrVecs[3*i+j] = tem_ctrlPt[j];
[ 本帖最后由 MIRRO_LEE 于 2009-2-27 20:21 编辑 ]
发表于 2009-3-3 19:50:33 | 只看该作者
加上调试语句看一下,画不出来一般会返回一个非0值,交给UG去判断好了
发表于 2009-3-3 19:52:09 | 只看该作者
即书上讲的UG_CALL(statement)
我一般就是这样解决的
发表于 2009-3-3 19:52:20 | 只看该作者
我一般就是这样解决的
发表于 2009-3-4 17:11:53 | 只看该作者
4# look_tfq
没太听懂楼上的意思。。。
能详细说明一下么?
发表于 2009-3-4 20:20:25 | 只看该作者
不是UG_CALL
是这个东西UF_CALL
把下面代码加到工程里就可以用了
代码如下
#define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X)))
static int report_error( char *file, int line, char *call, int irc)
    if (irc)
        char err[133],
             msg[133];
        sprintf(msg, "*** ERROR code %d at line %d in %s:\n+++ ",
            irc, line, file);
        UF_get_fail_message(irc, err);
        UF_print_syslog(msg, FALSE);
        UF_print_syslog(err, FALSE);
        UF_print_syslog("\n", FALSE);
        UF_print_syslog(call, FALSE);
        UF_print_syslog(";\n", FALSE);
        if (!UF_UI_open_listing_window())
            UF_UI_write_listing_window(msg);
            UF_UI_write_listing_window(err);
            UF_UI_write_listing_window("\n");
            UF_UI_write_listing_window(call);
            UF_UI_write_listing_window(";\n");
    return(irc);
发表于 2009-3-4 22:37:03 | 只看该作者
编译通过不等于你的程序就没有问题,最好自己调试,加些断点,看看问题出现在什么地方。
发表于 2009-3-9 10:28:47 | 只看该作者
本人编程时间尚短。。。
所以,嫩得很啊。。。
改了很久,调试了很久。。。还是不晓得问题出在哪里。。。
发表于 2009-3-9 13:53:04 | 只看该作者
也可以这样的比如
rec = UF_CURVE_create_spline_thru_pts(degree, periodicity, num_points, point_data, parameters, save_def_data, spline_tag);
如果你怀疑这句话有问题,那你就在下面加上
char message[133];
uf_get_fail_message(rec,message);
uc1601(message,1);
这样再运行程序,ug就会弹出对话框告诉你这个函数执行的问题了,有可能他会告诉你没问题,那你再找找其他的函数,总之这样自己调调就好了。
GMT+8, 2026-6-22 15:10 , Processed in 0.077289 second(s), 11 queries , Gzip On, Redis On.
