查看: 20077|回复: 27
[讨论] 谁见过这么奇怪的材料?
发表于 2009-3-17 17:56:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
同一种塑胶材料 厚度越大,防火等级越高, 可这种材料厚度越薄,防火等级越高,到UL 官方网站上查询也是这样,不知有谁见过或者用过?
QMFZ2 Component - Plastics
E50075
TEIJIN CHEMICALS LTD
HIBIYA DAIBIRU BLDG 2-2 UCHISAIWAI-CHO 1-CHOME CHIYODA-KU TOKYO 100-0011 JAPAN
Material Designation: L-1225#(f2), L-1225U#, L-1225V#, L-1225Z#(f1)
Product Description: Polycarbonate (PC), designated "anlite" furnished as pellets, powder.
Color
Min. Thick. (mm)
Flame Class
HWI
HAI
RTI Elec
RTI Imp
RTI Str
IEC GWIT
IEC GWFI
ALL
0.40
V-2
80
80
0.75
V-2
80
80
1.5
V-2
115
125
1.9
HB
115
125
3.0
HB
115
125
6.0
HB
115
125
CTI: 2
HVTR: 4
D495: 5
IEC Ball Pressure (°C): -
Dielectric Strength (kV/mm): 30
ISO Tensile Strength (MPa): -
ISO Tensile Impact (kJ/m2): -
Volume Resistivity (ohm-cm): 16
ISO Flexural Strength (MPa): -
ISO Izod Impact (kJ/m2): -
Dimensional Stability(%): 0
ISO Heat Deflection (°C): -
ISO Charpy Impact (kJ/m2): -
Material designation may be suffixed with any one or two letters.
(f1)
Suitable for outdoor use with respect to exposure to Ultraviolet Light, Water Exposure and Immersion in accordance with UL 746C.
(f2)
Subjected to one or more of the following tests: Ultraviolet Light, Water Exposure or Immersion in accordance with UL 746C, where the acceptability for outdoor use is to be determined by UL Inc.
Report Date: 2/10/1989
Underwriters Laboratories Inc®
UL94 small-scale test data does not pertain to building materials, furnishings and related contents. UL 94 small-scale test data is intended solely for determining the flammability of plastic materials used in components and parts of end-product devices and appliances, where the acceptability of the combination is determined by ULI.
发表于 2009-3-17 17:57:41 | 只看该作者
QMFZ2 Component - Plastics                E50075
Color        Min. Thick. (mm)        Flame Class        HWI        HAI        RTI Elec        RTI Imp        RTI Str        IEC GWIT        IEC GWFI
ALL         0.40        V-2        4        3        80        80        80        -        -
        0.75        V-2        3        1        80        80        80        -        -
        1.5        V-2        3        1        125        115        125        -        -
        1.9        HB        3        1        125        115        125        -        -
        3.0        HB        2        1        125        115        125        -        -
        6.0        HB        1        1        125        115        125        -        -
        CTI: 2        HVTR: 4        D495: 5        IEC Ball Pressure (°C): -
ISO Tensile Impact (kJ/m2): -        Volume Resistivity (ohm-cm): 16
ISO Izod Impact (kJ/m2): -        Dimensional Stability(%): 0
#        Material designation may be suffixed with any one or two letters.
(f1)        Suitable for outdoor use with respect to exposure to Ultraviolet Light, Water Exposure and Immersion in accordance with UL 746C.
(f2)        Subjected to one or more of the following tests: Ultraviolet Light, Water Exposure or Immersion in accordance with UL 746C, where the acceptability for outdoor use is to be determined by UL Inc.
Report Date: 2/10/1989        Underwriters Laboratories Inc®
这个更详细点
发表于 2009-3-17 18:28:59 | 只看该作者
是不是写错了,没见过这样的
发表于 2009-3-17 19:44:55 | 只看该作者
也不是不可能,技术在进步,只是用的少.
发表于 2009-3-17 20:43:30 | 只看该作者
路过踩一脚,
不过疑问:种材料厚度越薄,防火等级越高,这种好像跟常识不一样啊,难道这种材料多加几层变厚了,防火 效果就变差了,????????????/
不明
发表于 2009-3-17 22:43:22 | 只看该作者
3# wangxbjing
绝对没有写错,此塑胶料应该是日本帝人PC 料, 在UL 官方网站上牌号是E50075, 我感到很奇怪,因为现在有个产品准备用这种料,防火等级需要达到VO级,搞得现在拿不定主意
发表于 2009-3-18 00:07:37 | 只看该作者
都是不明白,帮顶了。
发表于 2009-3-18 10:34:26 | 只看该作者
顶一顶,看是否有人知道
发表于 2009-3-18 11:32:36 | 只看该作者
liu_q_m007 发表于 2009-3-17 22:43
3# wangxbjing
多少钱一吨啊
发表于 2009-3-18 11:42:49 | 只看该作者
找材料供应商一级一级往上问吧.
GMT+8, 2026-3-23 10:53 , Processed in 0.080856 second(s), 10 queries , Gzip On, Redis On.
