查看: 22584|回复: 5
[求助] VS2005二次开发菜单问题
发表于 2009-3-31 17:11:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
// menubar5.cpp : 定义 DLL 的初始化例程。
#include "stdafx.h"
#include "ProToolkit.h"
#include "user_tk_error.h"
#include "pro_wchar_t.h"
#include "ProMdl.h"
#include "ProMenu.h"
#include "ProMenuBar.h"
#include "ProMessage.h"
#include "ProNotify.h"
#include "ProObjects.h"
#include "ProUtil.h"
#include "ProUIDialog.h"
#include "ProUIMessage.h"
#include "ProUIPushbutton.h"
#include "ProSolid.h"
#include "ProWindows.h"
#include "ProFamtable.h"
#include "ProFaminstance.h"
#include "ProUICmd.h"
#include "TestError.h"
#include "ProParamval.h"
Application data types
extern "C"typedef struct user_command
    char *name;
    uiCmdCmdId id;
} UserCommand;
extern "C"typedef struct user_check_but
    uiCmdCmdId command;
    ProBoolean state;
} UserCheckBut;
Application global/external data
extern "C"static wchar_t msgfil[] =
    { 'm','e','n','u','b','a','r','_','m','s','g','.','t','x','t','\0'};
extern "C"static UserCheckBut check_but[2];
extern "C"static uiCmdAccessState access_state = ACCESS_AVAILABLE;
extern "C"static FILE *log_file = NULL;
extern "C"static UserCommand user_actions[] = {
{"TestCheckButtonOpt1", (uiCmdCmdId)NULL},
{"TestCheckButtonOpt2", (uiCmdCmdId)NULL},
{"TestRadioGroupOpt",  (uiCmdCmdId)NULL}};
    FUNCTION : ProTestAccessFunction()
    PURPOSE  :   Enable access
extern "C"static uiCmdAccessState ProTestAccessFunction(uiCmdAccessMode access_mode)
    return (ACCESS_AVAILABLE);
    FUNCTION : ProTestRadioButtonValue()
    PURPOSE  :  Set value for radio group
extern "C"int ProTestRadioButtonValue(
    uiCmdCmdId command,
    uiCmdValue *p_value)
    ProError err;
    ProMenuItemName  name;
#if 0
    err = ProMenubarMenuRadiogrpValueGet (p_value, name);
    err = ProMenubarMenuRadiogrpValueSet(p_value, name);
#endif
    return (0);
    FUNCTION : ProTestRadioButton()
    PURPOSE  :  Callback functions for radio group options
extern "C"int ProTestRadioButton(
    uiCmdCmdId command,
    ProError err;
    return(0);
    FUNCTION : ProTestCheckButtonValue()
    PURPOSE  :  Set new value for check buttons
extern "C"int ProTestCheckButtonValue(
    uiCmdCmdId command,
    ProError err;
    ProBoolean bool;
    int i;
    for (i=0; i<sizeof(check_but)/sizeof(check_but[0]); i++)
if (check_but[i].command == command)
         err = ProMenubarmenuChkbuttonValueGet (p_value, &bool);
     if (bool == check_but[i].state)
  continue;
     err = ProMenubarmenuChkbuttonValueSet(p_value, check_but[i].state);
     break;
    return(0);
    FUNCTION : ProTestCheckButton()
    PURPOSE  :  Callback function for check button options
extern "C"int ProTestCheckButton(
    uiCmdCmdId command,
    uiCmdValue *p_value,
    void *p_push_command_data)
    int i;
    ProMessageDisplay(msgfil, "TEST Check Button pressed.");
     /*  Change state of pressed button */
     check_but[i].state = !check_but[i].state;
     break;
    return(0);
  Function : ProTestMenuBar
  Purpose  : Create a menu to test Menu Bar functions
extern "C"int ProTestMenuBar()
    ProError err;
    uiCmdCmdId   push_act, push_act2, action;
    uiCmdCmdId   radio_act;
    int i;
    static ProMenuItemName radio_group_items[]=
{"TestRadio1", "TestRadio2", "TestRadio3", ""};
    static ProMenuItemLabel radio_group_labels[]=
{"Radio button 1", "Radio button 2", "Radio button 3", ""};
    static ProMenuLineHelp radio_group_help[]=
{"Test radio button", "Test radio button", "Test radio button", ""};
    Add new button to the menu bar
    err = ProMenubarMenuAdd( "TestMenuBar", "-MenuBar", "Help", PRO_B_FALSE,
msgfil);
    err = ProCmdOptionAdd("TestCheckButtonOpt1",
(uiCmdCmdActFn)ProTestCheckButton, PRO_B_TRUE,
(uiCmdCmdValFn)ProTestCheckButtonValue,
ProTestAccessFunction, PRO_B_TRUE, PRO_B_TRUE, &check_but[0].command);
    err = ProCmdOptionAdd("TestCheckButtonOpt2",
ProTestAccessFunction, PRO_B_TRUE, PRO_B_TRUE, &check_but[1].command);
    err = ProCmdOptionAdd("TestRadioGroupOpt",
(uiCmdCmdActFn)ProTestRadioButton, PRO_B_FALSE,
(uiCmdCmdValFn)ProTestRadioButtonValue,
ProTestAccessFunction, PRO_B_TRUE, PRO_B_TRUE, &radio_act);
    err = ProMenubarmenuChkbuttonAdd("TestMenuBar", "TestChkBut1",
"Check button 1",
"Test check button 1",NULL, PRO_B_TRUE, check_but[0].command,
msgfil);
    err = ProMenubarmenuChkbuttonAdd("TestMenuBar", "TestChkBut2", "Check button 2",
"Test check button 2", "TestChkBut1", PRO_B_TRUE, check_but[1].command,
msgfil);
    err = ProMenubarmenuRadiogrpAdd("TestMenuBar", "TestRadioGrp1",
3, radio_group_items, radio_group_labels, radio_group_help,
"TestChkBut2", PRO_B_TRUE, radio_act, msgfil);
    return(0);
extern "C"int user_initialize()
ProTestMenuBar();
return 0;
    End the Pro/TOOLKIT application
extern "C"void user_terminate()
     return;
发表于 2009-3-31 17:13:35 | 只看该作者
发表于 2009-3-31 19:22:20 | 只看该作者
发表于 2010-4-16 14:56:30 | 只看该作者
发表于 2010-4-26 16:22:01 | 只看该作者
发表于 2010-8-21 16:34:42 | 只看该作者
GMT+8, 2026-8-12 22:02 , Processed in 0.055745 second(s), 11 queries , Gzip On, Redis On.
