查看: 17626|回复: 7
[求助] DLL可以调用DLL吗
发表于 2009-4-2 15:09:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
假设有2个dll
1个是建立方块的 ->   1.DLL
1个是建立圆柱的 ->   2.DLL
我想在1.DLL中运行2.DLL创建圆柱,能实现吗?
发表于 2009-4-2 16:52:30 | 只看该作者
不会,帮你顶一个
发表于 2009-4-3 15:01:01 | 只看该作者
可以的!!!!
头像被屏蔽
发表于 2009-4-7 11:08:09 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-4-7 12:20:00 | 只看该作者
daojianrm 发表于 2009-4-7 11:08
可以,可以实现
有例子吗
发表于 2009-4-10 19:31:04 | 只看该作者
#include <ctype.h>
#include <stdio.h>
#include <uf.h>
#include <error_bases.h>
#define MAX_INPUT_SIZE  (8)  /* Larger than needed input buffer. */
typedef int (*XMPL_f_p_t)( int argc, char *argv[] );
Please add the correct file extension for a particular platform as follows:
HP - .sl
Windows NT - .dll
Digital Unix, IBM/AIX, SUN, SGI - .so
#define XMPL_SHLIB    ("ufd_example_shlib")
#define XMPL_FNC_A    ("ep_a")
#define XMPL_FNC_B    ("ep_b")
  * Loads a library and finds the function entry point specified by
  * the symbol name (sym), if necessary.  Calls the function with
  * supplied arguments and returns status.  The function pointer is
  * output for future use.
static int execute_lib(
  char       *lib,      /* I - Library Name.               */
  char       *sym,      /* I - Symbol Name.                */
  int         argc,     /* I - Argument Count.             */
  char       *argv[],   /* I - Arguments.                  */
  XMPL_f_p_t *fnc )     /* IO - Function Pointer for 'sym'.*/
    int error;
   /* Load library if necessary... */
  if( NULL == *fnc )
      UF_load_f_p_t generic_fnc;
    if( !(error = UF_load_library( lib, sym, &generic_fnc )) )
      *fnc = (XMPL_f_p_t) generic_fnc;
    else      /* Library load failed... */
         char message[133];
      UF_get_fail_message( error, message );
      fprintf( stderr,
        "ERROR: While loading \"%s\" (%s)...\n\t%s\n", lib, sym,
        message );
  else
    error = ERROR_OK;
   /* Execute function... */
  if( NULL != *fnc )
    error = (**fnc)( argc, argv );
  return( error );
  * A simple program to demonstrate dynamic loading and
  * unloading of shared libraries using UF_load_library
  * and UF_unload_library.  The program allows the user
  * to select one of two libraries to load and execute,
  * unload both libraries, or terminate the program.  Target
  * function prototypes are expected to match the 'C' 'main'
  * prototype (i.e. int fnc(int argc, char *argv[])).
/*ARGSUSED*/
extern int main(
  int   argc,
  char *argv[] )
    int error;
  if( !(error = UF_initialize()) )
      int done;
    done = 0;
    do
        char input[MAX_INPUT_SIZE+1];
       /* Display user choices... */
      printf( "\n\n" );
      printf( " 1 - Load and execute \"%s\" function.\n",
        XMPL_FNC_A );
      printf( " 2 - Load and execute \"%s\" function.\n",
        XMPL_FNC_B );
      printf( " 3 - Unload libraries.\n" );
      printf( " 4 - Terminate.\n\n" );
      printf( "Enter selection: " );
       /* Get user selection. */
      fgets( input, sizeof(input), stdin );
      printf( "\n\n" );
       /* Selection must be a single digit. */
      if( isdigit(input[0]) && '\n' == input[1] )
          static XMPL_f_p_t fnc_a = NULL;
          static XMPL_f_p_t fnc_b = NULL;
         /* Process selection... */
        switch( input[0] )
          case '1':   /* Load and execute first function... */
               char *xmpl_argv[] =
                   XMPL_SHLIB,  /* Library to load. */
                   XMPL_FNC_A,  /* Function to execute. */
                   "Called function ep_a in library ufd_example_shlib."
               int xmpl_argc = sizeof(xmpl_argv) /
                               sizeof(*xmpl_argv);
            error = execute_lib( xmpl_argv[0], xmpl_argv[1],
              xmpl_argc, xmpl_argv, &fnc_a );
          break;
          case '2':   /* Load and execute second function... */
               char *xmpl_argv[] =
                   XMPL_FNC_B,  /* Function to execute. */
                   "Called function ep_b in library ufd_example_shlib."
                               sizeof(*xmpl_argv);
              xmpl_argc, xmpl_argv, &fnc_b );
          break;
          case '3':   /* Unload library... */
            UF_unload_library( XMPL_SHLIB );
            fnc_a = NULL;
            fnc_b = NULL;
          break;
          case '4':   /* Finished - set termination flag. */
            done = 1;
          break;
          default:    /* Input character is out of range... */
            fprintf( stderr, "\nERROR: Invalid selection.\n" );
            break;
      else
        fprintf( stderr, "\nERROR: Select with digit only.\n" );
    } while( !done && !error );
    UF_terminate();
  else
       char message[133];
    fprintf( stderr, "ERROR: %s\n", message );
  return( 0 );
杨兄,以上代码可调用OK,
例: D:\UGS\NX 4.0\UGOPEN\ufd_load_library.c
发表于 2009-4-11 08:28:53 | 只看该作者
我要实现的就是类似XSPAWN的功能
XSPAWN/UFUN,'program name'[,IFERR,label:]这个就是grip执行DLL的函数,不管DLL里面有什么东西,只管执行就ok
发表于 2009-4-14 18:54:10 | 只看该作者
可以的.......
GMT+8, 2026-4-29 19:25 , Processed in 0.053815 second(s), 11 queries , Gzip On, Redis On.
