查看: 18375|回复: 8
[分享] VERICUT6.2.2对于X3与X3MU1的一些注意事项
发表于 2009-4-4 08:36:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
MasterCAM-to-VERICUT Interface (MCAMV)
A new feature, "Put operations in a single VERICUT setup", on the MCAMV Options
window, enables you to put the selected MasterCAM operations into one VERICUT
setup. Toggle "on" (checked) to put operations into one VERICUT setup. Toggle "off" to
put each MasterCAM operation in a separate VERICUT setup.
"Browse" buttons are added to simplify the selection of Part STL Files and Fixture STL
Files on the MCAMV main window.
MCAMV is enhanced to support multiple VERICUT G-Code tables. A new group of
features "VERICUT GCode Table" on the NXV Options window enable you to specify:
Table Name – Select Work Offset, Base Work Offset, Program Zero, or None from
the pull-down list.
Register Number – Enter the register number.
'From' Component — Select the name of the component that represents the "from"
point for determining the offset from the pull-down list. VERICUT will use the origin
of the specified component.
'To' Csys — Select the name of a CSYS to represent the "to" point for determining
the offset from the pull-down list. VERICUT will use the origin of the specified
CSYS.
Tool numbers created and passed through MCAMV to VERICUT now match the tool
numbers defined in MasterCAM X3. Due to differences between MasterCAM X3 and
MasterCAM X3 MU1, the following environment variable must be set as described
below to ensure that tool numbers are created and passed correctly through MCAMV to
VERICUT. Set the environment variable in the .bat file that you use to start MasterCAM
or set it using the Microsoft Control Panel > System > Advanced tab > Environment
Variable feature.
If you are using a MasterCAM part file created using the initial version of MasterCAM
X3, set the environment variable CGTECH_MCAMV_TLNO_IS_SLOT equal to 1as
shown below:
set CGTECH_MCAMV_TLNO_IS_SLOT=1
If you are using a MasterCAM part file created using MasterCAM X3 MU1 or later, do
not use this environment variable (or set it to 0).
主要是set CGTECH_MCAMV_TLNO_IS_SLOT=为1和0的注意点。
呵呵,现在的功能又增加了几个,有兴趣的可以用来对HSM刀路过切的检测
收藏收藏1 分享淘帖 赞一下!赞一下!
发表于 2009-4-4 08:37:51 | 只看该作者
发表于 2009-4-4 09:26:27 | 只看该作者
发表于 2009-4-4 10:08:27 | 只看该作者
发表于 2009-4-12 20:05:27 | 只看该作者
发表于 2009-4-12 20:10:40 | 只看该作者
发表于 2009-4-12 20:12:46 | 只看该作者
发表于 2009-8-30 08:29:38 | 只看该作者
发表于 2009-10-31 09:35:01 | 只看该作者
GMT+8, 2026-8-22 20:59 , Processed in 0.065428 second(s), 11 queries , Gzip On, Redis On.
