查看: 15996|回复: 1
[求助] 程序运行不止
发表于 2009-4-9 09:50:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
问下大家,为什么运行这个程序,就停不下来了,然后进程就死了。
代码贴这了。就是书上说的UF对象识别工具。
int CHANGE_ok_cb ( int dialog_id,
             void * client_data,
             UF_STYLER_item_value_type_p_t callback_data)
     /* Make sure User Function is available. */
     if ( UF_initialize() != 0)
          return ( UF_UI_CB_CONTINUE_DIALOG );
     /* ---- Enter your callback code here ----- */
  char prtname[133];
  UF_STYLER_item_value_type_t data[1];
  data[0].item_attr=UF_STYLER_VALUE;
  data[0].item_id=CHANGE_WIDE_S_0;
  UF_STYLER_ask_value(dialog_id,&data[0]);
  strcpy(prtname, data[0].value.string);
  tag_t part_tag;       // 部件标识
  UF_PART_load_status_t load_status;
  int status = UF_PART_open(prtname, &part_tag, &load_status);
  status = UF_MODL_update();
  status = UF_PART_save();
  tag_t tObj = NULL_TAG;
  int iType;
  int iSubtype;
  int iTypeTemp;
  char sLine[MAX_LINE_SIZE]="";
  UF_UI_open_listing_window();
  UF_UI_write_listing_window("Tag Type Subtype Layer");
  UF_UI_write_listing_window("\n--------------------");
  for(int i=1;i<2;i++)
  do
   UF_LAYER_cycle_by_layer(i,&part_tag);
   if(part_tag!=NULL_TAG)
    iTypeTemp = iType;
    UF_OBJ_ask_type_and_subtype(part_tag,&iType,&iSubtype);
    if(iTypeTemp!=iType)
     UF_UI_write_listing_window("\n");
    sprintf(sLine,"%7d %8d\n",tObj,iSubtype);
    UF_UI_write_listing_window(sLine);
  while(part_tag!=NULL_TAG);
     UF_terminate ();
    /* Callback acknowledged, terminate dialog             */
    /* It is STRONGLY recommended that you exit your       */
    /* callback with UF_UI_CB_EXIT_DIALOG in a ok callback.*/
    /* return ( UF_UI_CB_EXIT_DIALOG );                    */
    return (UF_UI_CB_EXIT_DIALOG);
发表于 2009-4-10 14:09:19 | 只看该作者
定义tag_t part_tag;时初始化一下,
改成tag_t part_tag = NULL_TAG; 再试试
GMT+8, 2026-4-29 22:42 , Processed in 0.057900 second(s), 11 queries , Gzip On, Redis On.
