查看: 16437|回复: 0
[原创] 求助!基于ADAMS四轮转向动力学仿真的毕业设计
发表于 2009-4-23 00:03:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我在做毕业设计,中间出了问题,现在卡住了不能进行,拜托高手指点,十分感谢。
我的设计是四轮转向,使用ADAMS2003,模型很简单,只画出前后悬架、转向杆、底盘、轮胎和路普。
前面进行的很顺利,在添加轮胎时弹出警告如下:
WARNING: Model .model_1 is no longer compatible with the ADAMS/Solver (C++).
.model_1.TIRE_1 is causing the incompatibility because:
   1) Objects of type Tire are not compatible with the
      ADAMS/Solver (C++).
   2) The topology of the model has changed so .model_1.TIRE_1
      is no longer connected in a way that is compatible with the
      ADAMS/Solver (C++).
   3) An attribute of .model_1.TIRE_1 is no longer compatible with
If you intend to use the ADAMS/Solver (C++), then be sure that you
set your preferences so ADAMS/Solver (C++) is the default as follows:
   - From the Settings menu, point to Solver and select either
     Solver Executable or Preferences, depending on the product
     you are using.
   - Press F1 in the dialog box that appears to learn more.
If you do not want to use the ADAMS/Solver (C++), you must change
your model to eliminate the incompatibilty.  See the online help
for the object listed for more information.
参数完全是李军UA轮胎参数,请问最后仿真失败和这有关么?轮胎文件应该放在哪个文件夹?求高手指点,谢谢。
GMT+8, 2026-8-2 15:35 , Processed in 0.055092 second(s), 13 queries , Gzip On, Redis On.
