查看: 17594|回复: 8
[求助] 无法分析变形
发表于 2009-4-25 21:42:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
希望有高手能帮忙
错误信息:
     Module Name = Moldex3D/Solid - Solid-Warp
     Version     = R9.0 (Build 9059.3) - 32Bit
     Website     : www.moldex3d.com
     (C) 1995-2009 CoreTech System Co., Ltd. All rights reserved.
>>>  Analysis start time: Sat Apr 25 21:34:53 2009
@@@( PROJECT INFORMATION
###( HomeDir:  E:\moldex3d\Moldex3DR900\
###( ProjDir:  E:\moldflow\2102
###( PrjName:  2102
###( RunNumb:  01
###( MshName:  E:\moldex3d\Moldex3DR900\
###( MatName:  PP_BorealisPPME300Z_1.mtr
###( ProName:  2102_1.pro
     Moldex3D-Solid/Warp 9059.3
<Mesh_Information>
    <General_Information>
        Mesh File Name                    = E:\moldflow\2102\Mesh\2101.mde
        Mesh File Version                 = 2006
        Total Element Number of Part      = 428494
        Total Node Number of Part         = 428494
        Total Element Number of Moldbase  = 0
        Total Node Number of Moldbase     = 0
        Total Element Number of Surface   = 243462
        Total Element Number              = 281789
        Total Node Number                 = 404974
    </General_Information>
    <Element_Type>
        eDesign Meshing Level             = 3
    </Element_Type>
    <Part_Mesh_Geometry>
        Volume of Cavity                  = 187.852 cc
        Volume of Cold Runner             = 0 cc
        Volume of Hot Runner              = 0 cc
        Total Volume                      = 187.852 cc
        x-coordinate Range                = (-8.58694, 7.72738) cm
        y-coordinate Range                = (-16.2947, 16.294) cm
        y-coordinate Range                = (0.0535382, 5.1533) cm
    </Part_Mesh_Geometry>
    <Moldbase_Geometry>
        Volume of Moldbase                = (32.6234 cm x 41 cm x 17.85 cm)
        x-coordinate Range                = (-16.5, 16.1234) cm
        y-coordinate Range                = (-20.5, 20.5) cm
        z-coordinate Range                = (-5.85, 12) cm
    </Moldbase_Geometry>
</Mesh_Information>
<Material_Information>
        Material File                     = E:\moldflow\2102\Material\PP_BorealisPPME300Z_1.mtr
        Material File Version             = 9007
        Polymer Name                      = PP
        Producer Name                     = Borealis A/S
        Polymer Trade Name                = Borealis PP ME300Z
        Polymer Comment                   = 30%talc
    <Polymer_Mechanical_Properties>
        Mechanical Type                   = Isotropic pure polymer
        Poisson's ratio v12               = 0.38
        Poisson's ratio v23               = 0.38
        Modulus E1(flow direction)        = 4.34e+010 dyne/cm^2
        Modulus E2(transverse direction)  = 4.34e+010 dyne/cm^2
        Shear Modulus G                   = 1.572e+010 dyne/cm^2
        CLTE a1(flow direction)           = 0.00015 1/K
        CLTE a2(transverse direction)     = 0.00015 1/K
    </Polymer_Mechanical_Properties>
    <Checking_Polymer_Data_Warning>
        Warning                           = None
    </Checking_Polymer_Data_Warning>
</Material_Information>
@@@(   NPROC MYID
@@@(   1 0
@@@( -- PROJECT INFORMATION --
@@@( HomeDir:  E:\moldex3d\Moldex3DR900\
@@@( ProjDir:  E:\moldflow\2102
@@@( PrjName:  2102
@@@( RunName:  01
@@@( RunFile:  E:\moldflow\2102\Analysis\Run01\210201.run
@@@( M3fFile:  E:\moldflow\2102\Analysis\Run01\210201.m3f
@@@( M3pFile:  E:\moldflow\2102\Analysis\Run01\210201.m3p
@@@( M3cFile:  E:\moldflow\2102\Analysis\Run01\210201.m3c
@@@( M3wFile:  E:\moldflow\2102\Analysis\Run01\210201.m3w
<Computer_Information>
      Operating System          = Microsoft Windows XP
      Version                   = Professional Edition Service Pack 3 (Build 2600)
      CPU                       = Intel(R) Pentium(R) Dual  CPU  E2200  @ 2.20GHz
    <Network_Information>
      Description               = Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit Ethernet NIC
      IP Address                = 192.168.1.7
      Subnet Mask               = 255.255.255.0
      Default Gateway           = 192.168.1.1
      MAC Address               = 00-23-54-dd-09-ba
    </Network_Information>
    <Memory_Information>
      Total Physical Memory     = 2047 MB
      Available Physical Memory = 1011 MB
    </Memory_Information>
</Computer_Information>
<Run_Settings_Information>
Max. no. iteration                  = 50000
Convergence tolerance               = 5.00e-005
Element type                        = Linear
Fiber orientation effect            = OFF
Remove runner                       = ON
In-mold constraint effect           = OFF
Moldbase deformation                = OFF
Flow-induced residual stress effect = OFF
Solver acceleration                 = ON
</Run_Settings_Information>
---> Pure polymer: Analyse C2M stage, please wait...
XXX ERROR  E5700 :
Symptom:
You may not have enough memory to run this case!
Solution:
Please try to increase your RAM or decrease total element number and rerun
the analysis again.
发表于 2009-4-26 10:12:23 | 只看该作者
Symptom:9 m: Z+ y% A8 {) g2 P
You may not have enough memory to run this case!! p! j) t7 D3 n" r
Solution:" [/ k7 P( i$ x* {# c$ A0 F
1 j9 N o+ g6 w% ]the analysis again.
说你没有足够的内存。
发表于 2009-4-26 11:59:36 | 只看该作者
可是我的内存已经2G了,难道还不够?
发表于 2009-4-26 21:24:30 | 只看该作者
2G算什么。没有8G你别它理你。
用过此软件。只能这样评价它“烂软件一个”
发表于 2009-4-27 07:47:15 | 只看该作者
谢谢上面两位,看来是没有办法了.
发表于 2009-4-27 09:35:21 | 只看该作者
CAE的翹曲對內存要求都比較高,MF和MDX都是這樣
发表于 2009-4-27 09:55:13 | 只看该作者
不知道用这些软件需要怎样的配置.
发表于 2009-4-27 10:06:08 | 只看该作者
要看你的元素數量,還要看你使用什么材料,含纖維的材料對內存要求較高
发表于 2009-4-27 10:07:09 | 只看该作者
現在市面上的電腦基本都可以滿足了,內存最好大點,其他的沒有特殊要求
GMT+8, 2026-6-14 01:25 , Processed in 0.065925 second(s), 11 queries , Gzip On, Redis On.
