查看: 15938|回复: 5
【求助】请斑竹指点!
发表于 2003-6-13 13:15:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
::?::?::?Bulk temperature 到底是甚末意思?Bulk temperature 为甚末会在出现Overpacking的地方降低?
发表于 2003-6-13 13:54:05 | 只看该作者
About the bulk temperature result
About this result
The temperature of polymer melt changes not only with time and location, but also with thickness during the entire injection molding cycle. It is difficult to illustrate all these changes in a single display. Instead, bulk temperature is used to indicate the weighted average temperature across the thickness. Bulk temperature has more physical significance than a simple average temperature as the polymer melt flows. Bulk temperature represents the energy that is transported through a particular location.
Using the Bulk temperature result
Bulk temperature is a velocity-weighted average temperature when the polymer is flowing and a simple average temperature when the flow stops. For each element, a plot of bulk temp versus time shows that the switch-over from bulk temperature to average temperature gives a smooth curve. Uniform bulk temperature distribution during filling is desirable for mold design.
Bulk temperature displays are an alternate way to examine the flow distribution. Areas with continuous flow (heat convection) typically have a higher bulk temperature. The bulk temperature drops quickly when the flow stops in that area.
Hot spots are indicated on the bulk-temperature contour or data-shaded plots during filling. Hot spots are due to excessive viscous heating during the filling stage.
If the maximum bulk temperature is close to the degradation temperature, consider redesigning the part geometry near the hot spot or changing the process conditions.
Differential temperature can also cause non-uniform shrinkage and warpage.
发表于 2003-6-13 14:29:50 | 只看该作者
Bulk temperature:意思就是每个点在厚度不同层上的温度加权平均值。表示每个位置的散热情况。注意不是表面温度,也不是中间层温度,而是加权平均温度。
Overpacking 的地方较低,我认为没什么特定理论,只是因为Overpacking的地方一般先充填完,凝固时间较其它地方长一点,所以散热多一点吧。
发表于 2003-6-13 19:45:27 | 只看该作者
听斑竹一言,胜读十年书
发表于 2003-6-14 15:13:22 | 只看该作者
请问:GROW FROM 是甚末意思?
发表于 2003-6-16 08:42:37 | 只看该作者
可以理解为胶料来源吧。显示的是各个浇口所填充的产品范围。
GMT+8, 2026-6-18 02:47 , Processed in 0.062254 second(s), 11 queries , Gzip On, Redis On.
