查看: 16128|回复: 0
[求助] 紧急求助,自定义子程序的例子(范老师书上的例子)
发表于 2009-9-4 14:43:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我在做范老师书上的一个例子
目的是得到motion的IC DISPLACEMENT,我已经将fortran弄成dll文件
然后在admas里面调用
可是仿真时出现如下错误:
ERROR:
ERROR:   Found an unexpected token while looking for an initial real argument value.
ERROR:      Statement           : MOTION
ERROR:      Argument            : ICDISP
ERROR:      Error line text     : '  MOTION/1,VELOCITY,ICDISP=     -149.543352  ,FUN=90d[[<eol>]]'
ERROR:      Error token text    : '<eol>'
ERROR:      Error token type    : end-of-statement
ERROR:      Initial displacement of MOTION model_1.MOTION_1 differs from that of
   JOINT model_1.JOINT_1, on which it is located, by -149.54 degrees.
从以上错误中看到,ICDISP=-149.54,已经计算出度数了,和下面提示的是相同的,这个错误是出在什么地方啊?
以下是fortran程序
SUBROUTINE CONSUB(PAR, NPAR)
C
C === Type and dimension statements ===================
C
C Note: For machines with 60 or more bits per word,
C       substitute "REAL" for "DOUBLE PRECISION".
C
C --- External variable definitions -------------------
C
      INTEGER                     NPAR
      DOUBLE PRECISION            PAR( * )
C
C PAR      Array containing passed parameters
C NPAR     Number of passed parameters
C
C --- Local variable definitions ----------------------
C
      LOGICAL          ERRFLG
      CHARACTER*80     COMMND
      INTEGER          STATUS, IPAR(2), IM, JM
      DOUBLE PRECISION  DIS2, WEI
C
C === Executable code =================================
C
C --- Initial static analysis -------------------------
C
C
C
      IM  = PAR(1)
      JM  = PAR(2)
C
      IPAR(1)  = IM
      IPAR(2)  = JM
      CALL SYSFNC('AZ', IPAR,2,DIS2,ERRFLE)
      WEI=-DIS2*57.2958
C
C --- Change the IC DISPLACEMENT of ERRFLG ---------------------------
C
      WRITE (COMMND,100) 'MOTION/1,VELOCITY,ICDISP=',WEI,',FUN=90d'
      CALL MODIFY(COMMND,STATUS)
100   FORMAT(A27,F16.6,A10)
C
急等回复
拜托
GMT+8, 2026-8-2 05:08 , Processed in 0.042807 second(s), 13 queries , Gzip On, Redis On.
