查看: 16877|回复: 4
MASTERCAM的快捷键
发表于 2003-7-4 10:49:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
MasterCAM的快捷键
To: Press:
Set the construction depth
  (Z) Alt + 0
Set the main system color
  Alt + 1
Set the main system level
  Alt + 2
Set a mask level Alt + 3
Set the tool plane (Tplane) Alt + 4
Set the construction plane (Cplane) Alt + 5
Set the graphics view (Gview) Alt + 6
Use AutoSave Alt + A
Make the toolbar visible/invisible Alt + B
Run C-Hooks Alt + C
Set drafting global parameters (PM) Alt + D
Access the Hide function Alt + E
Select a new menu font Alt + F
Access the Selection Grid Parameters dialog box Alt + G
Access online help Alt + H
List open files Alt + I
Access Job Setup parameters Alt + J
Set line style and line width Alt + L
View memory allocations Alt + M
Edit named views Alt + N
Access the Operations Manager dialog box Alt + O
Make the prompt area visible/invisible Alt + P
Undo the last operation Alt + Q
Edit the last operation Alt + R
Toggle full-time shading on/off Alt + S
View Mastercam version number and SIM serial number Alt + V
Set the viewport configuration Alt + W
Access the Xform menu Alt + X
Set visible levels Alt + Z
Access the Create, Arc, Circle 2 points function Alt + ‘
Fit geometry to the screen Alt + F1
Unzoom by 0.8 Alt + F2
Toggle cursor tracking on/off Alt + F3
Exit Mastercam Alt + F4
Access the Delete function using window selection Alt + F5
Access the Blank function Alt + F7
Access the System Configuration dialog box Alt + F8
Draw axes for the current world view (center), the current Cplane (lower-left), and the current Tplane (lower-right) Alt + F9
List all functions that can be assigned special keys. You can access a function by double-clicking its name from the list. Alt + F10
Zoom F1
Unzoom F2
Repaint F3
Access the Analyze menu F4
Access the Delete menu F5
Access the File menu F6
Access the Modify menu F7
Access the Create menu F8
Display the origins (system, construction, and tool), if defined, and the properties of the current file F9
List all functions that can be assigned special keys. You can access a function by double-clicking its name from the list. F10
Zoom in Page Up
Zoom out Page Down
Interrupt the system Esc
Pan Arrow buttons
发表于 2012-6-1 09:10:00 | 只看该作者
发表于 2012-6-1 12:12:19 | 只看该作者
发表于 2012-6-1 14:36:04 | 只看该作者
发表于 2012-6-17 10:25:35 | 只看该作者
GMT+8, 2026-8-21 17:44 , Processed in 0.055542 second(s), 12 queries , Gzip On, Redis On.
