查看: 16269|回复: 0
[求助] 总是出现问题
发表于 2010-7-5 23:26:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在跑的时候就会出现这个错误    望大侠帮忙解决一下!!! WARNING 701380 ** Warnings were reported in the model.
                     Mesh quality may be poor.
   Co-ordinates of mold extremity:
                         X             Y             Z
      Center          -35.07672 mm    -15.70879 mm     65.22000 mm
      Right corner    242.92995 mm    262.29787 mm    343.22667 mm
      Left  corner   -313.08338 mm   -293.71545 mm   -212.78667 mm
** ERROR 701580 ** Orientation of two adjacent elements is inconsistent.
                   Angle between normals = 9.00000E+01 deg degrees.
** ERROR 701590 ** Check the orientation of element    5302
** ERROR 701590 ** Check the orientation of element   24641
                   Angle between normals = 1.76478E+02 deg degrees.
** ERROR 701590 ** Check the orientation of element    5499
** ERROR 701590 ** Check the orientation of element   24640
** WARNING 98000 ** The following warning messages occurred more than 5 times:
              Message No. Number of occurrences
              701360       100
              701360       100 [img]file:///C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/)75N2NWKR]RF17ID@[M%{QJ.jpg[/img]
GMT+8, 2026-4-30 06:11 , Processed in 0.041333 second(s), 11 queries , Gzip On, Redis On.
