查看: 18289|回复: 0
[求助] UG二次开发:UF_OBJ_set_color问题
发表于 2010-7-18 17:03:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
想画几条颜色和线形不同的直线
extern int UF_OBJ_set_font (tag_t object_id, int font );
extern int UF_OBJ_set_color (tag_t object_id, int color );
但是画出来的3段直线 只有第一段直线 设置的线形和程序一样  第一段直线颜色不对
其他2段仍然是默认的线形和颜色
请各位大侠指点
#include "stdafx.h"
#include "main.h"
#include <uf_ui.h>
#include <uf_obj.h>
以下是核心代码
tag_t line[5];
double pt0[3]={0,0,0};
double pt1[3]={5,5,0};
double pt2[3]={10,5,5};
UF_CURVE_line_s  line_coords;
UF_CURVE_line_s  line_coords1;
UF_CURVE_line_s  line_coords2;
UF_VEC3_copy(pt0,line_coords.start_point);
UF_VEC3_copy(pt1,line_coords.end_point);
     UF_CURVE_create_line(&line_coords,&line[0]);
                UF_OBJ_set_color(line[0],UF_OBJ_RED);
                UF_OBJ_set_font(line[0],UF_OBJ_FONT_DASHED);
UF_VEC3_copy(pt1,line_coords1.start_point);
UF_VEC3_copy(pt2,line_coords1.end_point);
  UF_OBJ_set_color(line[1],UF_OBJ_YELLOW);
   UF_OBJ_set_font(line[1],UF_OBJ_FONT_CENTERLINE);
UF_VEC3_copy(pt2,line_coords1.start_point);
UF_VEC3_copy(pt3,line_coords1.end_point);
  UF_OBJ_set_color(line[2],UF_OBJ_CYAN);
   UF_OBJ_set_font(line[2],UF_OBJ_FONT_DOTTED);
GMT+8, 2026-8-4 01:46 , Processed in 0.042813 second(s), 11 queries , Gzip On, Redis On.
