请教大侠们:( S9 X1 c5 d! m7 K: J7 V
在proe转为CAD后,会自动生成- k' V( W; [5 o# ~4 B2 v& R& V0 I
0# K2 [+ h" g m: }) k5 k
DEFAULT_1, F4 F! k$ D, B+ P& b0 S s4 e
DEFAULT_2
) H$ |' d" k. R, s; U' W2 f aDEFAULT_3
4 M i9 k' X* `) Q/ H怎么把这些图层去掉。
/ X0 S3 J. {1 ? F& j' v2 P8 `, N3 v5 X% u# _
另:0 F/ z# n& X+ s$ h5 u q# y. I
我已经设置了如下的配置文件) f( k' u9 l i! I0 C' B7 G
DEFAULT_18 C. f9 g! r" x$ i7 F& @
DEFAULT_29 t0 l- B& A/ j6 _9 B( \3 \
DEFAULT_3+ L: F" q1 @# g. K I
输出的层还是
! i- q" R. o) C) bDEFAULT_1
. \/ s1 ^- O' L; G; wDEFAULT_25 R# ^, n- c5 j5 f0 E# @
DEFAULT_3
- W' |2 G! c4 y: n4 b! J: Q- w
0 t3 D* b2 Y6 x0 [
( a0 B w; k4 y& U9 ]* N6 w2 K+ o# ~dxf_export.pro
$ V: Q! O q* S: {. Zmap_color Centerline_COLOR 69 Q5 y2 X6 x+ @% M7 ^
map_color LETTER_COLOR 1 - _, K" z1 Q3 h) w* V9 e, G
map_color GEOMETRY_COLOR 7( m$ [* T2 |- G) K% L& D3 k
map_color sheetmetal_COLOR 7
9 z$ X) x" T7 a! B; X# h& |. pmap_color SECTION_COLOR 41 d/ s; V4 }- I2 Y# B1 t4 ^# i
map_color Leader_COLOR 36 W- ] |6 g- Q6 b
' K2 M* B, f5 \7 [5 {3 `( ~" Wmap_line_style CTRLFONT CENTER
1 j3 b M" w$ Y ]8 Q3 s3 Q& N: q3 D
) `& W: v* |( f6 ^6 b4 P( dmap_layer Dxf_Axis _axis# B8 y$ A3 L& l! f9 }% u
map_layer Dxf_Continuous_Line _solid
9 S2 t* Q0 \% ^0 R, ~& x$ m2 ]map_layer Dxf_Hidden_Line _hidden/ Y' j# D2 b- ?0 j6 B2 ]: _
map_layer Dxf_Dimension _dim
! a: B5 P8 y9 a# a9 g/ lmap_layer Dxf_Text _text6 c/ L: g2 V4 ], U H! E
map_layer Dxf_Hatching _section
/ x9 N4 ~/ \/ B) cmap_layer Dxf_Table _table6 x7 E- r2 ^0 m& h% ]8 N' r8 I
map_layer Dxf_Balloon _balloon
% ^9 S) h+ `+ vmap_layer Dxf_Format _format5 P5 @2 u) K6 A1 o( a0 y
( K- b; _6 Z4 v
map_layer 0 solid
: @- T% b( z# u# l; H3 tmap_layer 01___PRT_ALL_DTM_PLN solid 7 P' D. x! y3 q7 q! m3 I
map_layer 01___PRT_DEF_DTM_PLN solid
5 A2 ~* I2 n& z1 {: L: L0 tmap_layer 02___PRT_ALL_AXES solid ) B4 s* `# o5 M& L) n
map_layer 03___PRT_ALL_CURVES solid
1 @/ k0 r8 H% n$ `map_layer 04___PRT_ALL_DTM_PNT solid + b7 ^2 Y, y: A, J# [' k
map_layer 05___PRT_ALL_DTM_CSYS solid
Z) S: z: E3 l% x9 B) A. D3 }map_layer 05___PRT_DEF_DTM_CSYS solid
# b2 e# L0 T/ m `5 Y' nmap_layer 06___PRT_ALL_SURFS solid
& T, J0 j4 o+ b* amap_layer DEFAULT_1 solid
/ W3 o9 I% a) W* e0 Dmap_layer DEFAULT_2 solid 6 o: c% J5 y5 j, p) C4 R ]* H
map_layer DEFAULT_3 solid |
