查看: 21749|回复: 12
[分享] GPP2分割和重命名文件的方法
发表于 2010-11-8 22:39:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
中英文合并多看几遍也就看懂了。
希望对有些人有用。
一,分割
Anyway, this all revolves around the [size=105%]CUT_FILE system variable.
[size=105%]CUT_FILE系统变量正是这么做的,它减少了输出文件。
The [size=105%]CUT_FILE system variable does exactly that, it cuts the output file.
您将执行以下行添加到您的邮寄方式:
You would implement it by adding the following line to your post:
[size=105%]CUT_FILE = [size=105%]TRUE_;
[size=105%]CUT_FILE = [size=105%]TRUE_ ;
当GPP2发布引擎看到这个变量的值被设置为这个[size=105%]TRUE_,下列事件发生:
When the GPP2 posting engine sees that the value of this variable has been set to [size=105%]TRUE_ , the following events occur:
  • 后跳转到[size=105%]磁带的末尾作者:beforecut:块,并执行代码中有。
    The post jumps to the [size=105%]END OF TAPE: beforecut: block, and executes the code there.
    这是您将添加代码以启动行输出任何你需要在新的文件。
    This is where you would add code to output any startup lines you'll need in the new file.
    你很可能需要添加到您的文章这个区块,因为它是不包括在标准职位。
    You will most likely need to add this block to your post, as it is not included in the standard posts.
  • 切割后的G代码文件,并启动一个新的文件。
    The post cuts the g-code file and starts a new file.
  • 后跳转到[size=105%]磁带的开头作者:aftercut:块,并执行代码中有。
    The post jumps to the [size=105%]BEGINNING OF TAPE: aftercut: block, and executes the code there.
    这是您将代码添加到文件中的行输出任何的结束时,您将需要在您的新文件。
    This is where you would add code to output any end of file lines you'll need in your new file.
    再次,你最有可能需要添加到您的文章这个区块,因为它是不包括在标准职位。
    Once again, you will most likely need to add this block to your post, as it is not included in the standard posts.
  • 变量值的[size=105%]CUT_FILE系统重新设置为[size=105%]FALSE_。
    The value of the [size=105%]CUT_FILE system variable is set back to [size=105%]FALSE_ .
因此,如果添加[size=105%]CUT_FILE = [size=105%]TRUE_代码?
So, where to add the [size=105%]CUT_FILE = [size=105%]TRUE_ code?
那么,你要削减在刀具路径,所以你有两个选择。
Well, you want to cut at the toolpath, so you have two options.
  • [size=105%]年初[size=105%]TLPATH:
    The [size=105%]BEGINNING OF TLPATH: block
  • [size=105%]刀具路径[size=105%]会期:
    The [size=105%]END OF TOOLPATH: block
起初,你可能认为[size=105%]刀具路径会期:块将是最好的,因为它似乎是有意义的每缩短刀具路径的文件结尾。
At first, you might think the [size=105%]END OF TOOLPATH: block would be best, as it would seem to make sense to cut the file at the end of every toolpath.
不幸的是,这将增加在您的文件非常切成末,几乎没有给你一个额外的文件,如果任何代码。
Unfortunately, this would add a cut at the very end of your file, giving you an extra file with little, if any code in it.
因此,我们将不得不[size=105%]使用TLPATH开始:块。
So we'll have to use the [size=105%]BEGINNING OF TLPATH: block.
同一类型的问题,虽然在这里存在,因为我们不希望在削减后的第一刀路文件开始,所以我们需要做一个计数器来计算刀具路径,并在第二次才开始切割toolath。
The same type of problem exists here though, as we don't want the post to cut the file at the beginning of the first toolpath, so we'll need to make a counter to count the toolpaths, and only start cutting at the second toolath.
所以,首先你需要做的就是定义一个[size=105%]序列变量叫[size=105%]TPCOUNTER来计算刀具路径。
So the first thing you'll need to do is define a [size=105%]SEQUENCING variable called [size=105%]TPCOUNTER to count the toolpaths.
你一定想一[size=105%]开始就设置变量1 [size=105%]磁带的初始这个值[size=105%]块。
You'll want to set the initial value of this variable to 1 in the [size=105%]BEGINNING OF TAPE: block.
有一个在这个地方很多的变量初始化块的底部,所以只添加了那里。
There is a section at the bottom of this block where a lot of variable are initialized, so just add it there.
现在去你的[size=105%]开头TLPATH:块(此区块员额的标准在所有E8.5SP2P2,但需要被添加到旧文章),并添加以下行:
Now go to your [size=105%]BEGINNING OF TLPATH: block (this block is standard in all the E8.5SP2P2 posts, but will need to be added to older posts), and add the following lines:
[size=105%][size=105%]中频(TPCOUNTER“1)
[size=105%][size=105%]IF ( TPCOUNTER > [size=105%]1 )
[size=105%][size=105%]CUT_FILE = [size=105%]TRUE_;
[size=105%][size=105%]CUT_FILE = [size=105%]TRUE_ ;
[size=105%][size=105%]END_IF;
[size=105%][size=105%]END_IF ;
[size=105%]TPCOUNTER = TPCOUNTER + [size=105%]1;
[size=105%]TPCOUNTER = TPCOUNTER + [size=105%]1 ;
——www.jt258.com
收藏收藏3 分享淘帖 赞一下!赞一下!
发表于 2010-11-8 22:41:00 | 只看该作者
二命名
Time to take your coding skills to a new level. 但首先,一对G -代码Cimatron的命名文件的说明。 But first, an explanation of the g-code file naming in Cimatron.
对于一个从Cimatron的发布文件的默认名称为 The default name for a posted file from Cimatron is
ncfilename.toolpathname.postname ncfilename.toolpathname.postname
现在说你有分裂开启,并分成三个文件这个文件。 now say you have splitting turned on, and it splits this one file into three files. 现在,你会得到这些文件的名称。 You would now get these file names.
ncfilename.toolpathname.postname._01 ncfilename.toolpathname.postname._01
ncfilename.toolpathname.postname._02 ncfilename.toolpathname.postname._02
第一个文件名格式是比其他人不同。 The first filename format is different than the rest. 记得听这个,因为我们将要处理它以后。 Rememeber this, because we'll have to deal with it later on.
所以让我们说我们在每个刀具路径分裂我们的G代码,而我们要命名的刀具路径命名每个文件。 So lets say we're splitting our g-code at every toolpath, and that we want to name each file with the toolpath name. 很容易说,但很难做到。 Easy enough to say, but harder to do. 问题是,刀具路径名来来去去,但所有的文件重新命名,必须在发布过程结束时完成。 The problem is that toolpath names come and go, but all the file renaming has to be done at the end of the posting process. 因此,我们需要做的是使用一种编程方法称为数组。 So what we need to do is use a programming method called an array. 数组是比普通的变量不同。 An array is different than a regular variable. 定期变量可以保存单个值,而是一个数组可以存放任何值的数目,你如何定义它而定。 a regular variable can hold a single value, but an array can hold any number of values, depending on how you define it. 在我们的例子中,我们将需要一个数组,包含文本字符串,所以首先我们需要声明在喜欢这个岗位,格式部分是: In our case, we're going to need an array that holds text strings, so first we need to declare it in the FORMAT section of the post, like this:
格式 ( 字符 )TPNAME [50]; / /数组来保存50刀具路径名称 FORMAT ( CHARACTER ) TPNAME[ 50 ] ; //ARRAY TO HOLD 50 TOOLPATH NAMES
这个数组将容纳50刀具路径名称。 This array will hold up to 50 toolpath names. 接下来的步骤是虚拟数据填充到数组。 The next step is to populate the array with dummy data. 在GPP2,数组不喜欢的是空的,所以最好用一些虚拟的数据填充它们。 In GPP2, arrays don't like to be empty, so best to fill them with some dummy data. 这也给我们一些核对后。 This also gives us something to check against later. 因此,添加以下几行启动:块。 So add the following lines to the STARTUP: block.
/ /填充NULL数据TPNAME阵列 //FILL THE TPNAME ARRAY WITH NULL DATA
TPCOUNTER = 1; TPCOUNTER = 1 ;
重复 REPEAT
TPNAME [TPCOUNTER] =“空”; TPNAME[TPCOUNTER] = "NULL" ;
TPCOUNTER = TPCOUNTER + 1; TPCOUNTER = TPCOUNTER + 1 ;
直到 (TPCOUNTER == 51); UNTIL (TPCOUNTER == 51 ) ;
我们正在使用TPCOUNTER变量数到51在这里,仅仅是因为我喜欢用尽可能少的变量。 We're using the TPCOUNTER variable to count to 51 here, simply because I like to use as few variables as possible. 实际的TPCOUNTER初始值被设置在磁带结束的开始:块,所以使用它在这里不会伤害任何东西。 The actual initial value for TPCOUNTER gets set at the end of the BEGINNING OF TAPE: block, so using it here won't hurt anything. 该代码是非常简单。 The code is pretty simple. 经过重复循环的数组,填充每个点与空字。 The REPEAT loop goes through the array, filling each spot with the word NULL . 所以,现在,我们有充分的空数组。 So now, we have array full of NULL . 现在要与实际数据填充它。 Now to fill it with real data.
既然我们要填写姓名它与刀具路径,我们将加入以下行到TLPATH开始的开始:块。 Since we want to fill it with the toolpath names, we'll add the following line to the start of the BEGINNING OF TLPATH: block. 确保你把以前的代码行增加你的柜台上。 Make sure you put it before the line of code that increments your counter.
TPNAME [TPCOUNTER] = TP_NAME; TPNAME[TPCOUNTER] = TP_NAME ;
这是假设你使用一个变量称为TPCOUNTER数算你的刀具路径。 This is assuming that you're using a variable called TPCOUNTER to count your toolpaths. 所以,现在,在每个刀具路径开始,刀具路径名称获取存储在当前TPNAME阵列对应一个当场TLPATH举行的以数字为TPCOUNTER 开始在变量:块处理。 So now, at the beginning of every toolpath, the name of the current toolpath gets stored inside the TPNAME array in a spot that corresponds with number held in the TPCOUNTER variable as the BEGINNING OF TLPATH: block is processed. 因此,第一刀路名得到存储在点1,第二囤积现货2,依此类推。 So the first toolpath name gets stored in spot 1, the second gets stored in spot 2, and so on.
所以,我们要储存所有的数据,现在我们怎么用它做什么? So, we're storing all our data, now what do we do with it? 时间向下移动到 POST 脚本:块。 Time to move down to the POST SCRIPT: block. 这是块在这里我们可以创建DOS脚本命令操作如文件名的东西。 This is the block where we can create DOS scripting commands to manipulate things like file names. 该命令的system_call GPP2将创建这些DOS命令。 The GPP2 command SYSTEM_CALL will create these DOS commands. 如果你有到这里做任何文件重命名任何其他代码,现在是时候评论它,因为所有的这些代码假定它是唯一的代码现在重命名文件的工作。 If you have any other code down here doing any file renaming, now's the time to comment it out, because all this code assumes that it is the only code working on file renaming right now.
首先,我们将添加代码来处理第一个文件。 First we'll add the code to deal with the first file. 如果你还记得,这个文件的名称不同(没有在文件名末尾有多余的编号)。 If you remember, this file is named differently (no extra numbering at the end of the file name). 我们还可以假设,总是会有至少这一个文件。 We can also assume that there will always be at least this one file. 我也要去,认为你的G代码文件后缀将是。数控。 I'm also going to assume that your g-code file suffix is going to be .nc. 这是一个什么样的事情发生在这个代码列表。 Here is a list of what's going to happen in this code.
1.使用的system_call删除任何文件可能已经存在具有相同的名称,我们想用我们的第一个文件。 Use a SYSTEM_CALL to delete any file that might already exist that has the same name that we want to use for our first file.
2.使用的system_call来重命名第一个G代码文件的刀具路径名第一。 Use a SYSTEM_CALL to rename the first g-code file to the name of the first toolpath.
3.变量file_name的 GPP2系统存储的文件的默认名称的第一个。 GPP2 stores the default name of the first file in the system variable FILE_NAME . 它使用它来告诉系统哪个文件打开记事本或什么,当你完成张贴。 It uses this to tell the system which file to open in Notepad or whatever, when you're done posting. 嗯,我们只是改变了该第一个文件的名字,但我们仍然需要知道更多的文件重命名后的默认名称。 Well we just changed the name of that first file, but we still need to know the default name for renaming more files later on. 所以我们要存储的值称为FULLFILENAME举行的file_name中各自的变量在变量我们。 So we're going to store the value held in the FILE_NAME variable in a variable of our own called FULLFILENAME . 您将需要声明这个变量在字符的格式为您的文章区。 You will need to declare this in the FORMAT area of your post as a CHARACTER variable.
4.最后,我们可以设定file_name的价值的系统变量的第一个文件的新名称我们。 and finally, we'll set the value of the system variable FILE_NAME to the new name of our first file.
该代码将看起来像这样: The code will look like this:
的 system_call“删除”TPNAME [1]“数控。”; / /删除要使用的任何现有名称相同的文件与作为名称,我们 SYSTEM_CALL "del " TPNAME[ 1 ] ".nc" ; // REMOVE ANY EXISTING FILES WITH THE SAME NAME AS THE NAME WE WANT TO USE
“仁”file_name的“”TPNAME [1]“。数控 的system_call”; / /重命名系统文件张贴到所需要的文件名 SYSTEM_CALL "ren " FILE_NAME " " TPNAME[1] ".nc" ; //RENAME SYSTEM POSTED FILE TO DESIRED FILENAME
FULLFILENAME = file_name的 ; / /存储为NAME使用默认文件后对 FULLFILENAME = FILE_NAME ; //STORE THE DEFAULT FILE NAME FOR USE LATER ON
file_name的 = TPNAME [1] +“数控。”; / /告诉系统什么是新的文件名 FILE_NAME = TPNAME[ 1 ] + ".nc" ; // TELL THE SYSTEM WHAT THE NEW FILENAME IS
现在到了其他文件。 Now for the other files. 我们将在这里需要另一个柜台,因为我们是从第二个刀具路径上创建的文件现在,但是默认的编号方案添加一个。_01到第二个文件,所以我们的刀具路径计算是从编号方案计数一次性。 We're going to need another counter here, because we're now on the file created from the second toolpath, but the default numbering scheme add a ._01 to the second file, so our toolpath count is one off from the numbering scheme count. 为了使这条赛道的,你需要声明一个特殊格式的变量,使用一种格式的用户 。 To keep track of this, you will need to declare a specially formatted variable, using one of the USER formats. GPP2有10个自定义格式(USER_1通过USER_10),您可以定义,我们需要定义一个总是输出两个整数。 GPP2 has 10 custom formats ( USER_1 thru USER_10 ) that you can define, and we need to define one that always outputs two integers. 所以,选一个,这不是在您的文章已被使用,并使用。df2设置为2的整数部分的最小和最大位数。 So pick one that's not being used in your post already, and use the .df2 to set the min and max digits for the integer part to 2. 因为我们需要的文件编号总是用这两个数字格式。 We need this because of the format of the file numbering always using two digits. 一旦你的用户格式设置,并宣布继续进行您的文章第一个变量的格式,称为FILECOUNTER英寸 Once you have the USER format setup, go ahead and declare a variable called FILECOUNTER in the FORMAT section of your post. 一旦你这样做了,现在让我们来看看什么会发生在这个接下来的代码段。 Once you've done that, now lets take a look at what will happen in this next section of code.
1.请检查是否有连第二个文件。 Check to see IF there is even a second file. 我们将尽空此点在第二个数组的检查,看它是否拥有比其他任何东西的话。 We'll do this by checking the second spot in the array to see if it holds anything other than the word NULL .
2.设置变量值的FILECOUNTER为1。 Set the value of the FILECOUNTER variable to 1. 我们将使用这个默认的文件来跟踪数量递增,而我们的第一个文件,它使用的增量编号开始。 We'll use this to track the default file increment number, and we're starting on the first file that uses the increment numbering.
3.设置变量值的TPCOUNTER为2。 Set the value of the TPCOUNTER variable to 2. 我们将用它来跟踪刀具路径数,我们的第二个刀具路径开始。 We'll use this to track the toolpath number, and we're starting on the second toolpath.
4.启动一个循环来处理文件名 Start a loop to process the filenames
5.使用的system_call删除任何文件可能已经存在具有相同的名称,我们要使用的下一个文件。 Use a SYSTEM_CALL to delete any file that might already exist that has the same name that we want to use for the next file.
6.重命名的system_call使用当前默认命名文件中的值取决于TPCOUNTER的FILECOUNTER值由目前的刀具路径确定的名称。 Use a SYSTEM_CALL to rename the current default named file determined by the FILECOUNTER value with the current toolpath name determined by the TPCOUNTER value.
7.递增FILECOUNTER变量。 Increment the FILECOUNTER variable.
8.变量递增TPCOUNTER Increment the TPCOUNTER variable
9.这样做,直到我们找到一个空位置的数组,在数组中的下一个景点,仍持有该单词。 Do this until we find a spot in the array that the next spot in the array, still holds the word NULL .
10.END_IF如果该开始了这一进程。 END_IF the IF that started this process.
中频 (TPNAME [2]!=“空”)/ /只有进程,如果有第二个刀具路径 IF (TPNAME[ 2 ] != "NULL" ) //ONLY PROCESS IF THERE IS A SECOND TOOLPATH
FILECOUNTER = 1; / /设置初始值 FILECOUNTER = 1 ; //SET THE INITIAL VALUE
TPCOUNTER = 2; / /设置初始值 TPCOUNTER = 2 ; //SET THE INITIAL VALUE
重复 REPEAT
的 system_call“删除”TPNAME [TPCOUNTER]“。数控”; / /删除相同名称的任何现有文件与 SYSTEM_CALL "del " TPNAME[TPCOUNTER] ".nc" ; // REMOVE ANY EXISTING FILES WITH THE SAME NAME
的 system_call“仁”FULLFILENAME]。“数控”。_“FILECOUNTER”“TPNAME; [TPCOUNTER”/ /重命名名文件从默认到当前刀具路径名称 SYSTEM_CALL "ren " FULLFILENAME "._" FILECOUNTER " " TPNAME[TPCOUNTER] ".nc" ; //RENAME THE FILE FROM THE DEFAULT NAME TO THE CURRENT TOOLPATH NAME
FILECOUNTER = FILECOUNTER + 1; / /递增计数器 FILECOUNTER = FILECOUNTER + 1 ; //INCREMENT THE COUNTER
TPCOUNTER = TPCOUNTER + 1; / /递增计数器 TPCOUNTER = TPCOUNTER + 1 ; //INCREMENT THE COUNTER
直到 (TPNAME [TPCOUNTER] ==“空”); / /停止,如果是ARRAY下一个景点的不持有刀具路径名称 UNTIL (TPNAME[TPCOUNTER] == "NULL" ) ; //STOP IF THE NEXT SPOT IN THE ARRAY DOES NOT HOLD A TOOLPATH NAME
END_IF; END_IF ;
发表于 2010-11-8 23:16:55 | 只看该作者
多谢,正在找这方面的东东!
发表于 2010-11-9 00:31:00 | 只看该作者
多谢你的资料  正在学gpp2 呵呵  不知道楼主能不能解决我的一个问题
在交互区增加一个选项  选择是否输出 比如G5.1Q1  G5P10000来选择  需要输出到程序头
不知道这个是怎么实现的
谢谢
发表于 2010-11-9 02:49:29 | 只看该作者
虽然不懂GPP2    但是知道是好东西  顶起...
发表于 2010-11-9 07:26:42 | 只看该作者
呵呵,你这个谁都看不懂,机器翻译的吧?反而不如直接看英文原文:
Anyway, this all revolves around the CUT_FILE system variable. The CUT_FILE system variable does exactly that, it cuts the output file. You would implement it by adding the following line to your post:
    CUT_FILE = TRUE_ ;
When the GPP2 posting engine sees that the value of this variable has been set to TRUE_, the following events occur:
The post jumps to the END OF TAPE: beforecut: block, and executes the code there. This is where you would add code to output any startup lines you'll need in the new file. You will most likely need to add this block to your post, as it is not included in the standard posts.
The post jumps to the BEGINNING OF TAPE: aftercut: block, and executes the code there. This is where you would add code to output any end of file lines you'll need in your new file. Once again, you will most likely need to add this block to your post, as it is not included in the standard posts.
The value of the CUT_FILE system variable is set back to FALSE_ .
So, where to add the CUT_FILE = TRUE_ code? Well, you want to cut at the toolpath, so you have two options.
The BEGINNING OF TLPATH: block
The END OF TOOLPATH: block
At first, you might think the END OF TOOLPATH: block would be best, as it would seem to make sense to cut the file at the end of every toolpath. Unfortunately, this would add a cut at the very end of your file, giving you an extra file with little, if any code in it. So we'll have to use the BEGINNING OF TLPATH: block. The same type of problem exists here though, as we don't want the post to cut the file at the beginning of the first toolpath, so we'll need to make a counter to count the toolpaths, and only start cutting at the second toolath. So the first thing you'll need to do is define a SEQUENCING variable called TPCOUNTER to count the toolpaths. You'll want to set the initial value of this variable to 1 in the BEGINNING OF TAPE: block. There is a section at the bottom of this block where a lot of variable are initialized, so just add it there.
Now go to your BEGINNING OF TLPATH: block (this block is standard in all the E8.5SP2P2 posts, but will need to be added to older posts), and add the following lines:
    IF( TPCOUNTER > 1 )
        CUT_FILE = TRUE_ ;
    END_IF ;
Time to take your coding skills to a new level. But first, an explanation of the g-code file naming in Cimatron.
now say you have splitting turned on, and it splits this one file into three files. You would now get these file names.
The first filename format is different than the rest. Rememeber this, because we'll have to deal with it later on.
So lets say we're splitting our g-code at every toolpath, and that we want to name each file with the toolpath name. Easy enough to say, but harder to do. The problem is that toolpath names come and go, but all the file renaming has to be done at the end of the posting process. So what we need to do is use a programming method called an array. An array is different than a regular variable. a regular variable can hold a single value, but an array can hold any number of values, depending on how you define it. In our case, we're going to need an array that holds text strings, so first we need to declare it in the FORMAT section of the post, like this:
FORMAT (CHARACTER) TPNAME[50] ; //ARRAY TO HOLD 50 TOOLPATH NAMES
This array will hold up to 50 toolpath names. The next step is to populate the array with dummy data. In GPP2, arrays don't like to be empty, so best to fill them with some dummy data. This also gives us something to check against later. So add the following lines to the STARTUP: block.
    TPCOUNTER = 1 ;
    REPEAT
    UNTIL (TPCOUNTER == 51) ;
We're using the TPCOUNTER variable to count to 51 here, simply because I like to use as few variables as possible. The actual initial value for TPCOUNTER gets set at the end of the BEGINNING OF TAPE: block, so using it here won't hurt anything. The code is pretty simple. The REPEAT loop goes through the array, filling each spot with the word NULL. So now, we have array full of NULL. Now to fill it with real data.
Since we want to fill it with the toolpath names, we'll add the following line to the start of the BEGINNING OF TLPATH: block. Make sure you put it before the line of code that increments your counter.
This is assuming that you're using a variable called TPCOUNTER to count your toolpaths. So now, at the beginning of every toolpath, the name of the current toolpath gets stored inside the TPNAME array in a spot that corresponds with number held in the TPCOUNTER variable as the BEGINNING OF TLPATH: block is processed. So the first toolpath name gets stored in spot 1, the second gets stored in spot 2, and so on.
So, we're storing all our data, now what do we do with it? Time to move down to the POST SCRIPT: block. This is the block where we can create DOS scripting commands to manipulate things like file names. The GPP2 command SYSTEM_CALL will create these DOS commands. If you have any other code down here doing any file renaming, now's the time to comment it out, because all this code assumes that it is the only code working on file renaming right now.
First we'll add the code to deal with the first file. If you remember, this file is named differently (no extra numbering at the end of the file name). We can also assume that there will always be at least this one file. I'm also going to assume that your g-code file suffix is going to be .nc. Here is a list of what's going to happen in this code.
GPP2 stores the default name of the first file in the system variable FILE_NAME. It uses this to tell the system which file to open in Notepad or whatever, when you're done posting. Well we just changed the name of that first file, but we still need to know the default name for renaming more files later on. So we're going to store the value held in the FILE_NAME variable in a variable of our own called FULLFILENAME. You will need to declare this in the FORMAT area of your post as a CHARACTER variable.
    SYSTEM_CALL "del " TPNAME[1] ".nc" ; // REMOVE ANY EXISTING FILES WITH THE SAME NAME AS THE NAME WE WANT TO USE
    FILE_NAME = TPNAME[1] + ".nc" ;// TELL THE SYSTEM WHAT THE NEW FILENAME IS
Now for the other files. We're going to need another counter here, because we're now on the file created from the second toolpath, but the default numbering scheme add a ._01 to the second file, so our toolpath count is one off from the numbering scheme count. To keep track of this, you will need to declare a specially formatted variable, using one of the USER formats. GPP2 has 10 custom formats (USER_1 thruUSER_10) that you can define, and we need to define one that always outputs two integers. So pick one that's not being used in your post already, and use the .df2 to set the min and max digits for the integer part to 2. We need this because of the format of the file numbering always using two digits. Once you have the USER format setup, go ahead and declare a variable called FILECOUNTER in the FORMAT section of your post. Once you've done that, now lets take a look at what will happen in this next section of code.
Check to see IF there is even a second file. We'll do this by checking the second spot in the array to see if it holds anything other than the word NULL.
Set the value of the FILECOUNTER variable to 1. We'll use this to track the default file increment number, and we're starting on the first file that uses the increment numbering.
Set the value of the TPCOUNTER variable to 2. We'll use this to track the toolpath number, and we're starting on the second toolpath.
Do this until we find a spot in the array that the next spot in the array, still holds the word NULL.
    IF (TPNAME[2] != "NULL") //ONLY PROCESS IF THERE IS A SECOND TOOLPATH
        REPEAT
        UNTIL (TPNAME[TPCOUNTER] == "NULL") ; //STOP IF THE NEXT SPOT IN THE ARRAY DOES NOT HOLD A TOOLPATH NAME
    END_IF ;
发表于 2010-11-9 14:04:26 | 只看该作者
发表于 2010-11-9 17:43:00 | 只看该作者
这个中英文看的蛋疼。。
发表于 2013-11-19 22:31:32 | 只看该作者
  惭愧 看不懂英文。。。。。。。。。
发表于 2015-10-21 18:38:07 | 只看该作者
这个中英文看的蛋疼。。
GMT+8, 2026-6-11 17:59 , Processed in 0.070441 second(s), 12 queries , Gzip On, Redis On.
