查看: 16258|回复: 1
[讨论] 请高人帮我看看程序错在哪里
发表于 2010-11-26 23:34:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
程序的目的是通过对话框给工作部件添加一个文件属性。编译时提示错在红色部份那里。不知错在哪里,请高人指点。
错误提示:(error C2440: 'initializing' : cannot convert from '' to 'int (__cdecl *)(int,void *,struct UF_STYLER_item_value_type_s *)'
        None of the functions with this name in scope match the target type)
下面是程序内容:
#include <stdio.h>
#include <uf.h>
#include <uf_defs.h>
#include <uf_exit.h>
#include <uf_ui.h>
#include <uf_styler.h>
#include <uf_mb.h>
#include <uf_part.h>
#include <uf_modl.h>
#include <uf_attr.h>
#include <uf_cfi.h>
#include <uf_assem.h>
#define MY_TH               ("TH")
#define MY_DIALOG_OBJECT_COUNT  ( 1 )
int MY_ok_fun(int dialog_id,
  char *client_data,
  UF_STYLER_item_value_type_p_t callback_data);
    int LaunchProDesignDialog( int *response );
#define MY_CB_COUNT ( 1 + 1 ) /* Add 1 for the terminator */
static UF_STYLER_callback_info_t MY_cbs[MY_CB_COUNT] =
{UF_STYLER_DIALOG_INDEX, UF_STYLER_OK_CB, 0, MY_ok_fun},
{UF_STYLER_NULL_OBJECT, UF_STYLER_NO_CB, 0, 0 }
static UF_MB_styler_actions_t actions[] = {
    { "att.dlg",  NULL,   MY_cbs,  UF_MB_STYLER_IS_NOT_TOP },
    { NULL,  NULL,  NULL,  0 } /* This is a NULL terminated list */
extern int LaunchProDesignDialog( int *response )
    int  error_code = 0;
    if ( ( error_code = UF_initialize() ) != 0 )
           return (0) ;
    if ( ( error_code = UF_STYLER_create_dialog ( "att.dlg",
           MY_cbs,      /* Callbacks from dialog */
           MY_CB_COUNT, /* number of callbacks*/
           NULL,        /* This is your client data */
           response ) ) != 0 )
          char fail_message[133];
          /* Get the user function fail message based on the fail code.*/
          UF_get_fail_message(error_code, fail_message);
          UF_UI_set_status (fail_message);
          printf ( "%s\n", fail_message );
   UF_terminate();
    return (error_code);
  char *client_data,
  UF_STYLER_item_value_type_t data;
  UF_ATTR_value_t value;
  if ( UF_initialize() != 0)
          return ( UF_UI_CB_CONTINUE_DIALOG );
       data.item_attr=UF_STYLER_VALUE;
   data.item_id=MY_TH;
   UF_STYLER_ask_value(dialog_id,&data);
   value.type=UF_ATTR_string;
   value.value.string=data.value.string;
   UF_ATTR_assign(UF_ASSEM_ask_work_part (), "图号", value);
      UF_terminate ();
return (UF_UI_CB_CONTINUE_DIALOG);
return (UF_UI_CB_EXIT_DIALOG);
发表于 2010-11-26 18:33:42 | 只看该作者
GMT+8, 2026-8-4 04:26 , Processed in 0.043024 second(s), 11 queries , Gzip On, Redis On.
