查看: 18562|回复: 1
[求助] “撤销成功,会话可安全进行”是什么问题?
发表于 2011-6-2 21:04:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
小弟初学UG二次开发,最近做了一个长方体,编译连接都通过了,就是在UG里运行不出来,显示信息为“撤销成功,会话可安全进行”,请哪位好心的坛友帮忙看下,源代码奉上。由于文件太大,不能上传,只把OK回调函数的代码穿上:
int BLOCK_ok_cb ( int dialog_id,
             void * client_data,
             UF_STYLER_item_value_type_p_t callback_data)
     /* Make sure User Function is available. */
     if ( UF_initialize() != 0)
          return ( UF_UI_CB_CONTINUE_DIALOG );
     /* ---- Enter your callback code here ----- */
          tag_t  blk_obj_id ;
     double base_pt [ 3 ]={0,0,0} ;
   char edges[3][130];
   double a;
   double b;
   double c;
   UF_STYLER_item_value_type_t data[3];
   data[0].item_attr=UF_STYLER_VALUE;
   data[0].item_id=BLOCK_REAL_A;
   UF_STYLER_ask_value(dialog_id,&data[0]);
   data[1].item_attr=UF_STYLER_VALUE;
   data[1].item_id=BLOCK_REAL_B;
   UF_STYLER_ask_value(dialog_id,&data[1]);
   data[2].item_attr=UF_STYLER_VALUE;
   data[2].item_id=BLOCK_REAL_C;
   UF_STYLER_ask_value(dialog_id,&data[2]);
   a=data[0].value.real;
   b=data[1].value.real;
         c=data[2].value.real;
   int sig=8;
   gcvt(a, sig ,edges[0]);
   gcvt(b, sig ,edges[1]);
   gcvt(c, sig ,edges[2]);
   char *edges_len[130]={edges[0],edges[1],edges[2]};
   UF_MODL_create_block1(UF_NULLSIGN,base_pt,edges_len,&blk_obj_id);
     UF_terminate ();
    /* Callback acknowledged, terminate dialog             */
    /* It is STRONGLY recommended that you exit your       */
    /* callback with UF_UI_CB_EXIT_DIALOG in a ok callback.*/
    /* return ( UF_UI_CB_EXIT_DIALOG );                    */
    return (UF_UI_CB_EXIT_DIALOG);
发表于 2011-6-4 11:56:25 | 只看该作者
GMT+8, 2026-8-3 21:50 , Processed in 0.108392 second(s), 11 queries , Gzip On, Redis On.
