查看: 16822|回复: 4
[求助] 各位进来帮下忙好吗
发表于 2011-6-20 14:08:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
系统重装后E8.5 E9.0就都装不上去  LIC文件的MAC地址都改成本机地址后 双击create_lic 生成的本机可用许可证有问题
Cimatrone.lic:line 35:Invalid parameter Context: <your FLEXlm error: -42,298 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com". cimatrone.lic:line 49:Invalid parameter Context: <your FLEXlm error: -42,298 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com". cimatrone.lic:line 51:Invalid parameter Context: <your FLEXlm error: -42,298 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com". cimatrone.lic:line 35: "FEATURE ODT_SHOOT_PACKAGE cima-d 8.5 31-dec-2012 uncounted" Hostid required for uncounted feature Invalid license file syntax FLEXlm error: -2,269 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com". cimatrone.lic:line 49: "FEATURE ODT_CATALOGS cima-d 8.5 31-dec-2012 uncounted" Hostid required for uncounted feature Invalid license file syntax FLEXlm error: -2,269 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com". cimatrone.lic:line 51: "FEATURE CHINESE_TRANSLATION cima-d 8.5 31-dec-2012 uncounted" Hostid required for uncounted feature Invalid license file syntax FLEXlm error: -2,269 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com".
#FEATURE CORE_ELECTRODE cima-d 8.5 31-dec-2012 uncounted
# HOSTID=000b2f2b28b3 ISSUER="Team oDDiTy" SIGN=6DBC437817BE
FEATURE CORE_STANDARD cima-d 8.5 31-dec-2012 uncounted \
HOSTID=000b2f2b28b3 ISSUER="Team oDDiTy" SIGN=72FC7626FCCA
PACKAGE ODT_SHOOT_PACKAGE cima-d 8.5 COMPONENTS="$oDDiTy_rOX SLA CORE \
CONCURRENT_DESIGN CATALOGTOOL KINEMATICS QSPLIT DIE_FORM \
DIE_BLANK DIE_STRIP DIE_TOOLS DIE_PLOT DIE_SET DIE_LABEL \
2X-MILL 3X-MILL 3X_SIMULATOR 5X_SIMULATOR NC-LINK CAD_MODE \
QUICKDRILL MACHINE_SIM MOLDDESIGN QELECTROD QCOMPARE AUTODRAW \
AUTOMATED_DRILL BEND CATIA CATIAR2D CATIAR3D CATIAW2D CATIAW3D \
CIMACABLE CIMADEK CIMADEK-NC CIMADEK-RUN CIMARENDER CIMIT-M \
CIMIT-N CIMIT-D CIMIT-MD CIMIT-MDN CIMIT-MN CORE-M CORE-X CPDM \
DIE_FLANGE E_STAMP QUICK_NC GPF DRAFT EDMS-LINK \
EDM_SETUP_WIZARD EDM_WIZ_AGIE EDM_WIZ_DPC EDM_WIZ_INGERSOL \
EDM_WIZ_MITSUBISHI ELECTRODE FAST_BLANK FIKUS_IGUS FUSION_FULL \
GPP2_DEV_EX2 GPP2_3X GPP2_5X GPP2_DEV_DF2 DIE_LABEL LATHE_2X \
LATHE_3X LATHE_PP_COMPILER MACHINE_SIM_CONFIG MACRO \
MICROSCRIBE_IF MICRO_3X MICRO_5X MOLD-EXPERT MOLDBASE3D \
MULTI-USER-1 MULTI-USER-2 MX-MOTION-EDITOR NC_UNDERCUT NESTING \
NETWORK_ENABLED PAR-SHAPE PARASOLID_READ PARASOLID_SAT \
POST_CONFIG POST_DEVELOPMENT POST_PRO POST_RUN PUNCH Q5X_CONT \
QCON_C QCON_Q QCON_S QUICKCONCEPT RD-PTC RE-ENGE R_CATIA5 \
R_CATIA_2D R_CATIA_SAT R_IGES R_IGES_SAT R_INVENTOR \
R_PARASOLID R_PROE R_SOLIDWORKS R_STEP R_STEP_SAT R_UG R_VDA \
R_VDA_SAT R_VRML SHOP-NC SIMULATOR SOLFAST_FULL SOLID \
SOLID-ASSEMBLY STEP_READ STEP_WRITE SURFM TACFAST_FULL \
VERIFIER V_CONTROLLER WF2SRF WIRE_2X WIRE_4X WIRE_STANDALONE \
W_CATIA5 W_CATIA_SAT W_IGES W_IGES_SAT W_PARASOLID W_STEP \
W_STEP_SAT W_UG W_VDA W_VDA_SAT W_VRML X-CIMADEK X-CIMADEK-RUN \
DIE_PLOT_THICK DIE_PLOT_SAFETY 5X_AEROSPACE 5X_TRIM 4X-CONT \
5X-CONT 2X-WIRE 4X-WIRE ABIANT IGES GPP FEM VDA DXF 2D-TO-3D \
SAT DWG DMS TEMP_KEY_CODE UGR3D MX_MOTION_BUILDER STL \
ADVANCED_ASSEMBLY 2X_MILL_LITE 3X_MILL_LITE" SIGN=337FEC1054FC
PACKAGE ODT_CATALOGS cima-d 8.5 COMPONENTS="CATALOG_DANLY_INCH \
CATALOG_DANLY_MM CATALOG_DAYTON_INCH CATALOG_DAYTON_MM \
CATALOG_DME_INCH CATALOG_DME_MM CATALOG_DMS CATALOG_FIBRO \
CATALOG_FUTABA CATALOG_HASCO_INCH CATALOG_HASCO_MM \
CATALOG_HOPPT CATALOG_HYSON_INCH CATALOG_HYSON_MM \
CATALOG_KISHIN CATALOG_LKM CATALOG_MEUSBURGER CATALOG_MISUMI \
CATALOG_NATIONAL CATALOG_OKSET CATALOG_OTHER1 CATALOG_OTHER2 \
CATALOG_OTHER3 CATALOG_OTHER4 CATALOG_PCS CATALOG_PEDEROTTI \
CATALOG_POLIMOLD CATALOG_PROGRESSIVE CATALOG_RABOURDIN \
CATALOG_SIDECO CATALOG_SISCAT CATALOG_SKF CATALOG_STAMPI \
CATALOG_STRACK CATALOG_SYSTEM3R CATALOG_TEKIS CATALOG_TVMP \
CATALOG_UNI CATALOG_VAP" SIGN=0D2396A668C8
安装后一直都打不开  我都装了不只五十次了。。。。 重装之前都没这样的问题 很顺利就完成了  谁能帮忙解决下吗  不胜感激
发表于 2011-6-20 20:06:54 | 只看该作者
发表于 2011-6-20 20:29:22 | 只看该作者
发表于 2011-6-21 20:39:10 | 只看该作者
发表于 2011-6-21 22:06:18 | 只看该作者
GMT+8, 2026-8-23 21:30 , Processed in 0.058305 second(s), 11 queries , Gzip On, Redis On.
