查看: 17523|回复: 0
[求助] gambit网格划分(求助)
发表于 2011-8-2 09:53:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
gambit网格划分(求助)用UG建模,保存成IGS,GAMBIT接收正常(因为在GAMBIT中不会用圆角,只好用UG做了),划分网格,设置边界,输出网格扩展名为msh.
> Reading "D:\www\3\qidao.msh"...
Interrupting...
  112255 nodes.
   15544 mixed wall faces, zone  2.
    3646 mixed pressure-outlet faces, zone  3.
   14584 mixed pressure-inlet faces, zone  4.
  190732 mixed wall faces, zone  5.
Error: no cells in zone, id = 0, ind1 = 1, indn = 0Reading Cells: failed while reading section 12.
       Clearing partially read grid.
Error: Read aborted due to critical error.
Error Object: ()
Error: Error reading "D:\www\3\qidao.msh".
Error Object: #f
问题是用GAMBIT划分的网格,fluent接受错误,请高手指点,要是能帮忙划分网格不胜感激。邮箱wsm_30@126.com
GMT+8, 2026-8-20 11:41 , Processed in 0.107467 second(s), 10 queries , Gzip On, Redis On.
