查看: 16237|回复: 1
【求助】UF_MODL_trim_sheet 的用法
发表于 2003-8-16 09:54:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的问题是我用的时候该命令什么都没做。不知道为什么
void trimed_sheet_prj(tag_t line_t[],tag_t sheet_tag)
    // tag_t line_t[],工具曲线tag_t sheet_tag,被剪切的曲面
     int count_bounding_objects=1;
     UF_MODL_trim_object   trim_objects[8];
     UF_MODL_trim_object_p_t trim_objects_p[8];
     double  projection_vector[3]={0,0,1};
     int point_key=0;
     int point_count=1;
     double  point_coords[3]={3000,3000,2015};
   double tolerance=0.0254;
   int * number_gap_points;
   double ** gap_points;
   for(int i=0;i<8;i++)
     trim_objects_p = [$trim_objects]
   for(i=0;i<8;i++)
         trim_objects_p->object_tag = line_t;
         trim_objects_p->curve_project_method = 1;
      UF_MODL_trim_sheet (sheet_tag, count_bounding_objects, trim_objects_p,
                     projection_vector,0, point_count, point_coords,
                         tolerance,  number_gap_points,  gap_points );
发表于 2009-7-30 15:22:49 | 只看该作者
这函数没有返回修剪后的片体的TAG值?怎么获得呢?
GMT+8, 2026-4-29 04:57 , Processed in 0.042689 second(s), 12 queries , Gzip On, Redis On.
