查看: 15945|回复: 1
【求助】简单的AutoLISP语言转换成C语言-没人会?
发表于 2003-8-16 17:12:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我有一些AutoLisp的程序看不懂,请各位帮我翻译成C语言形式。谢谢!
(defun YPZL(/ f data2 c d l2 h d1 v1 v2a v2b v2 vo vn v3 v4 v5a v5b v5c v5 h1 v m ) //data2 后面为变量,这个句子我不理解
(setq f (open (getfiled "select a file" "d:\\1hx\\" ""8)"r")
(setq data2(list))
(setq c (read-list f)
(while (/=c nil)
         (rline c)
         (setq data2 (append data2 datalist))
         (setq c (read-line f)
:argument of list
(setq d(list 'l' 'l1' 'r1' 'r2' 'r3' 'r4' 'r5' 'k1' 'k2' 's3' 'h2' 'h4' 'h8' 'h9' 'z' 'p' 't1' h3' 'h6'
   'h7' 'c1' 'c2'))
(jjfz d data2)
(close f)
//又一段
the data evaluated to argument
(defun jjFz (fhao shu / i n a b )
(setq i 0)
(setq n (length fhao))
  (repeat n
(setq a (ntn i fhao))
  (setq b (ntn i fshu))
(set a b)
(setq i (i+1))
;read-line of string and the string change to data of list
(defun rline (c / str i s1 lettero letter)
    (setq datalist (list))
    (setq str "")
   (setq i l)
   (setq s1 (strlen c)
   (setq lettero " " letter " ")
   (repeat s1)
(setq lettero letter)
(setq letter (substr c i l))
(if (/= lettrer " ")
     (if (/=letter ",")
              (setq str (strcat str letter))
  (cond ( ( or (and (or ( and (>lettero "/") (<lettero ":") )(lettero "."))
                             (or (=letter " ")(=letter "," ) )
                        (= i s1 )
              (setq datalist (cons (atof str ) datalist ))
              (setq str " ")
     (setq i ( 1+i)
  (setq datalist (reverse datdalist))
发表于 2003-8-17 00:00:12 | 只看该作者
GMT+8, 2026-8-24 02:57 , Processed in 0.053219 second(s), 12 queries , Gzip On, Redis On.
