查看: 16956|回复: 7
【求助】UF_MODL_ask_extrusion函数的使用问题,救急!!!
发表于 2003-8-24 13:54:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
利用该函数查询拉伸的参数,其中许多参数需要初始化和释放操作,请教如何正确的初始化和释放操作。
函数的说明如下:
extern UFUNEXPORT int UF_MODL_ask_extrusion(
tag_t feature_obj_id ,/* <I>
                      Object tag for the extruded feature
int* num_objects ,/* <O>
                  Number of curves
tag_t** objects ,/* <OF>
                &nbspointer to an array containing the tags of the extruded curves.
                 This array must be freed by calling UF_free.
UF_MODL_SWEEP_TRIM_object_p_t* trim_ptr ,/* <OF>
                                        &nbspointer to structure for trimming data.
                                         This pointer may be returned as NULL,
                                         if trimming objects are not used.
                                         NEEDS A FREE ROUTINE
char** taper_angle ,/* <OF>
                    Taper angle.  This must be freed by calling UF_free.
char* limits[2] ,/* <OF>
                 Limits of extrusion.  Each element of this array must be
char* offsets[2] ,/* <OF>
                  Offsets for open strings.  Each element of this array must be
double region_point[3] ,/* <O>
                       &nbspoint on region desired.
logical* region_specified ,/* <O>
                           True or False for region desired.
logical* solid_creation ,/* <O>
                         TRUE = a solid body.
double direction[3]  /* <O>
                     Extrusion direction
发表于 2003-8-24 19:51:34 | 只看该作者
发表于 2003-8-26 14:40:33 | 只看该作者
发表于 2003-8-26 19:24:27 | 只看该作者
发表于 2003-8-27 09:38:57 | 只看该作者
发表于 2003-8-27 09:41:52 | 只看该作者
发表于 2003-8-27 14:04:26 | 只看该作者
发表于 2003-8-28 09:02:46 | 只看该作者
GMT+8, 2026-8-3 22:46 , Processed in 0.055669 second(s), 11 queries , Gzip On, Redis On.
