查看: 15980|回复: 3
[求助] 求各位指点旋转的程序!
发表于 2011-11-17 14:16:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
实体是在草图画好后拉伸的,不是程序生成的,现在要用程序把这个实体旋转一个角度,该怎么实现啊?我写的程序如下,但是运行后没有反应。编译没有问题的,求给为大神指点
tag_t displayed_part;
        displayed_part = UF_PART_ask_display_part();
         int type1;
        tag_t solid;
        type1 = UF_solid_type;
        solid = NULL_TAG;
  tag_t  tag_solid[4];
  char mess[133];
  int i=4;
  do
   UF_OBJ_cycle_objs_in_part(displayed_part,type1,&solid );
   int type2,subtype,body_type;
   UF_OBJ_ask_type_and_subtype(solid, &type2, &subtype);
   if(subtype == UF_solid_body_subtype)
    UF_MODL_ask_body_type (solid, &body_type);
    if (body_type==UF_MODL_SOLID_BODY)
     tag_solid[i]=solid;
     sprintf(mess,"%d",tag_solid[i]);
     i++;
    } while (solid != NULL_TAG);  //获取图中的部件
double origin[3]={0.0,0.0,0.0};
        double direction[3]={1.0,0.0,0.0};
  double degrees_rotation=45;
  double matrix[16];
  int status;
  FTN(uf5945)(origin,direction,&degrees_rotation,matrix,&status);
        int ip3=1;
  int ip4=1;
        int ip5=-1;
  int ip6=1;
  int ir9;
        tag_t nr7,nr8;
  const tag_t np2[1]={solid};
        FTN(uf5947)(matrix,&solid,&ip3, & ip4, &ip5, & ip6, &nr7, &nr8, &ir9);
发表于 2011-11-17 18:40:31 | 只看该作者
发表于 2011-11-17 18:59:22 | 只看该作者
发表于 2011-11-18 10:44:28 | 只看该作者
GMT+8, 2026-8-3 15:50 , Processed in 0.048267 second(s), 11 queries , Gzip On, Redis On.
