查看: 18417|回复: 0
[讨论] dynaform分析中遇到的一些问题 ,期待高手。
发表于 2012-1-13 21:35:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1. ITERATION LIMIT REACHED,AUTOMATICALLY REFORMING STIFFNESS MATRIX
2.   Warning:       3 negative eigenvalues detected
3. *** Error Memory is set          17280 words short
           Current memory size           3000
           Increase the memory size by one of the following
           where #### is the number of words requested:
            1) On the command line set - memory=####
            2) In the input file define memory with *KEYWORD
               i.e., *KEYWORD #### or *KEYWORD memory=####
4.
    *** Warning Memory is set            5787707 words short
             increase the memory size to     32002107
5. E r r o r   t e r m i n a t i o n
   Memory required for explicit solution  :     69851073
   Additional dynamically allocated memory:      1816681
                                     Total:     71667754
6.Warning reset D3PLOT ouput interval from 0. to   1.6000E-03
7.ERROR CAN NOT OPEN FILE *** on unit.
GMT+8, 2026-7-26 13:36 , Processed in 0.240729 second(s), 12 queries , Gzip On, Redis On.
