查看: 15990|回复: 0
[求助] 大家帮帮忙,看看我这段代码!
发表于 2012-4-17 15:38:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
代码编译生成通过了,结果在UG里加载运行后不出结果..我想按长度延伸一个曲面,选择了已有曲面的一条边,但是好像函数返回值是11(正常是0),查了UF_MODL_error.h  好像是LIST_SMALLER_THEN_INDEX  不明白,大家帮忙看看吧
  1. #include <stdio.h>
  2. #include <malloc.h>
  3. #include <uf.h>
  4. #include <uf_ui.h>
  5. #include <uf_disp.h>
  6. #include <uf_modl.h>
  7. #include <uf_modl_trex.h>
  8. #include <uf_modl_form_features.h>
  9. #define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X)))
  10. static int report_error( char *file, int line, char *call, int irc)
  11. {
  12. if (irc)
  13. {
  14. char err[133],
  15. msg[133];
  16. sprintf_s(msg, 64,"*** ERROR code %d at line %d in %s:\n+++ ",
  17. irc, line, file);
  18. UF_get_fail_message(irc, err);
  19. UF_print_syslog(msg, FALSE);
  20. UF_print_syslog(err, FALSE);
  21. UF_print_syslog("\n", FALSE);
  22. UF_print_syslog(call, FALSE);
  23. UF_print_syslog(";\n", FALSE);
  24. if (!UF_UI_open_listing_window())
  25. {
  26. UF_UI_write_listing_window(msg);
  27. UF_UI_write_listing_window(err);
  28. UF_UI_write_listing_window("\n");
  29. UF_UI_write_listing_window(call);
  30. UF_UI_write_listing_window(";\n");
  31. }
  32. }
  33. return(irc);
  34. }
  35. static void do_ugopen_api(void)
  36. {
  37. ////////
  38. char cue[] = "Select Objects";
  39. char title[] = "User Title";
  40. int response, count;
  41. tag_p_t objects;
  42. ///////
  43. char buffer[1000];
  44. int algorithm_version;
  45. UF_MODL_TREX_appl_data_p_t f_data;
  46. UF_MODL_TREX_data_set_p_t targets[1];
  47. UF_MODL_TREX_extend_method_t method;
  48. UF_MODL_TREX_to_option_t t_option;
  49. UF_MODL_TREX_region_option_t r_option;
  50. int make_coner=0;
  51. int keep_boundaries=0;
  52. int extract_sheets= 0;
  53. double dist_tol=0.5;
  54. tag_t f_tag=NULL_TAG;
  55. long i,k,m;
  56. targets[0]=(UF_MODL_TREX_data_set_p_t)malloc(sizeof(UF_MODL_TREX_data_set_t));
  57. f_data = (UF_MODL_TREX_appl_data_p_t)malloc(sizeof(UF_MODL_TREX_appl_data_t));
  58. ///////////////////
  59. if((UF_CALL(UF_UI_select_with_class_dialog(
  60. cue, title, UF_UI_SEL_SCOPE_WORK_PART,
  61. NULL, NULL, &response, &count,&objects))) == 0) /////////objects中我选择了已有曲面的一条边
  62. {
  63. if (response == UF_UI_OK && count > 0)
  64. {
  65. k=UF_MODL_TREX_init_trex_data(f_data);
  66. m=UF_MODL_TREX_init_trex_data_set(targets[0]);
  67. method= UF_MODL_TREX_NATURAL;
  68. r_option = UF_MODL_TREX_KEEP;
  69. t_option = UF_MODL_TREX_DISTANCE;
  70. algorithm_version= UF_MODL_TREX_ALGORITHM_NONE;
  71. dist_tol=0.5;
  72. extract_sheets= 0;
  73. keep_boundaries=0;
  74. make_coner=0;
  75. targets[0]->collector = objects[0];
  76. targets[0]->offset_val = 0;
  77. targets[0]->reversed = 0;
  78. targets[0]->extend_val= 10;
  79. UF_DISP_set_highlight(targets[0]->collector, 0);
  80. UF_free(objects);
  81. f_data->targets = targets;
  82. f_data->dist_tol = dist_tol;
  83. f_data->extend_method =method;
  84. f_data->make_corner = make_coner;
  85. f_data->num_targets = 1;
  86. f_data->num_tools = 0;
  87. f_data->region_option = r_option;
  88. f_data->keep_boundaries = keep_boundaries;
  89. f_data->to_option = t_option;
  90. f_data->algorithm_version = algorithm_version;
  91. i=UF_MODL_TREX_create_trex_feature(f_data,&f_tag);
  92. UF_UI_open_listing_window();
  93. sprintf_s(buffer,64,"%ld\n",i); //////////这块我输出了上面函数返回值 显示是11 查了下UF_MODL_error.h
  94. //////////发现是LIST_SMALLER_THEN_INDEX 也搞不懂
  95. UF_UI_write_listing_window(buffer);
  96. UF_MODL_TREX_free_trex_data(f_data);
  97. }
  98. }
  99. }
  100. extern DllExport void ufusr( char *parm, int *returnCode, int rlen )
  101. {
  102. /* Initialize the API environment */
  103. if( UF_CALL(UF_initialize()) )
  104. {
  105. /* Failed to initialize */
  106. return;
  107. }
  108. do_ugopen_api();
  109. /* TODO: Add your application code here */
  110. /* Terminate the API environment */
  111. UF_CALL(UF_terminate());
  112. }
  113. extern int ufusr_ask_unload( void )
  114. {
  115. return( UF_UNLOAD_UG_TERMINATE );
  116. }
复制代码
GMT+8, 2026-8-3 13:50 , Processed in 0.056069 second(s), 13 queries , Gzip On, Redis On.
