查看: 16468|回复: 0
【推荐】TIG焊接温度场和流场的模拟
发表于 2003-11-22 06:28:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
转自仿真
https://www.simwe.com/cgi-bin/ut/topic_show.cgi?id=27450&h=1#148159
这是我做的模拟的命令流,问题一定不少,希望高手们不吝赐教!
/FILNAME,flotran,0
/TITLE,flotran transient analysis
/PREP7
smrt,off
ET,1,fluid142
KEYOPT,1,1,2
BLOCK,-0.025,0.025,-0.01,0,-0.25,0.25,
block,-0.004,0.004,-0.01,0,-0.25,0.25,
vsel,s,volu,,1,2
vovlap,all
vglue,all
NUMCMP,LINE
NUMCMP,AREA
NUMCMP,VOLU
/REPLOT
AESIZE,ALL,0.002,
LESIZE,ALL,0.002, , , ,1, , ,1,
ESIZE,0.002,0,
MSHKEY,1
MSHAPE,0,3d
vmesh,2,3
AESIZE,ALL,0.002,
ESIZE,0.002,0,
MSHKEY,1
MSHAPE,0,3d
vmesh,1
/VIEW, 1 ,1,1,1
/ANG, 1
/REP,FAST
/psf,hflu,,2,0
/PNUM,LINE,1
asel,s,,,12,16,4!最上层节点的速度vy设为0,其他的速度为0.其他表面节点仍设为三个方向的速度为0
asel,a,,,6
nsla,s,1
d,all,vy,0
allsel,all
asel,s,ext,,all
asel,u,,,12,16,4
asel,u,,,6
nsla,s,1
D,all,,,,,,VX,vy,vz
asel,s,,,12,16,4
asel,a,,,1,2,1
nsla,s,1
sf,all,conv,50e-6,293
asel,s,,,5
asel,a,,,11,15,4
nsla,s,,,1
sf,all,conv,25e-6,293
allsel,all
!flow environment
FLDATA15,PRES,REFE,101350,
FLDATA16,BULK,BETA,1e+015,
FLDATA17,GAMM,COMP,1.4,
FLDATA14,TEMP,NOMI,293,
FLDATA14,TEMP,TTOT,293,
FLDATA14,TEMP,BULK,293,
TOFFSET,0,
nsel,s,,,all
ic,all,sp01,1.0
ic,all,sp02,0.0
finish
/solu
allsel,all
!*solution options
FLDATA1,SOLU,TRAN,1 !瞬态分析
FLDATA1,SOLU,FLOW,1
fldata1,solu,temp,1
/COM,,Transient Analysis,1
FLDATA4,TIME,STEP,2!自定义时间步时间间隔2秒
FLDATA4,TIME,ISTEP,0,
FLDATA4,TIME,NUMB,10,
FLDATA4,TIME,TEND,8!设置结束时间8秒
FLDATA4,TIME,GLOB,10, !设置每个时间步多少次运算
FLDATA4,TIME,PRES,1e-006,
FLDATA4,TIME,TEMP,1e-006,
FLDATA4,TIME,APPE,2 !设置记录时间间隔
FLDATA4A,STEP,SUMF,10,
FLDATA4,TIME,SUMF,1.0e6
FLDATA4,TIME,BC,0
fldata2,iter,exec,30
fldata2,iter,over,2
fldata5,outp,sumf,30
!*fluid properties
fldata13,vary,dens,1
FLDATA7,PROT,DENS,LIQUID
FLDATA8,NOMI,DENS,7800,
FLDATA9,COF1,DENS,300,
FLDATA10,COF2,DENS,0.0001,
FLDATA11,COF3,DENS,0,
FLDATA7,PROT,visc,1
FLDATA7,PROT,VISC,LIQUID
FLDATA8,NOMI,VISC,1,
FLDATA9,COF1,VISC,300,
FLDATA10,COF2,VISC,1644,
FLDATA11,COF3,VISC,0,
FLDATA7,PROT,cond,constant
flda,nomi,cond,70
FLDATA7,PROT,spht,constant
fldata8,nomi,spht,470
!*flow environment
acel,0,-9.81,0
fldata18,meth,pres,1
fldata19,tdma,pres,100
FLDA,OUTP,SP01,T
FLDA,OUTP,SP02,T
csys,0
nsel,s,loc,y,0
csys,2
nsel,r,loc,x,0,0.006
csys,0
sf,all,hflux,50000000!%ga%!热源是固定的,此处热流应该加高斯分布的,不过我加了以后得出的结果和实际温度场差别很大,就用这个代替了,如果是移动热源,ga为200*24*0.6*100/{PI}/{PI}/
(0.003^2)*exp(-1e6*100*({X}^2+({Z}-8.3e-3* {TIME})^2)),不知哪个参数取得不对?
allsel,all
solve
!下面是一位师姐教我的用一个循环加载表面张力,对此还是一窍不通,还请高手指点!
*do,i,1,8
time=i*0.01
/post1
set,last
!此处应该获取节点温度,不知该如何做?
/solu
csys,0
nsel,s,loc,y,0
csys,2
nsel,r,loc,x,0.001,0.006!加表面张力我用了一个近似
csys,0
F,all,FX,%tx%!tx为0.00001*{X}/sqrt({X}^2+{Z}^2)
F,all,FZ,%tz%!tz为0.00001*{Z}/sqrt({X}^2+{Z}^2)
allsel,all
solve
*enddo
GMT+8, 2026-8-20 10:32 , Processed in 0.066534 second(s), 11 queries , Gzip On, Redis On.
