查看: 17182|回复: 5
[求助] 这是什么意思啊
发表于 2012-5-24 20:05:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
(defun c:mjd ()
4 q+ h" i! R2 v; K4 a9 N  (prompt "请输入要求非标面积的层名:  ")( c7 j: U3 R5 j
  (setq aly (getstring))
. b+ P& r+ w% f' t  (command "layer" "s" "0" "f" "*" "t" aly "")
1 P; F! ~8 P/ G0 d7 n  (setq ena (ssget "x" '((8 . "025"))) n (sslength ena) i 0)
) e; A2 Q5 P- S, L  (setvar "clayer" "0")(setvar "cmdecho" 0)
+ x1 p* q* |' m- N7 v5 s2 p2 f& P  (while (setq ena (entsel "选择图形: "))
# c% B2 S  t% l2 I    (setq en (car ena) ee (entget en) ee (entget en) )2 _0 o* S5 M: u% k, b
    (command "list" en "")  Y1 t! x$ q* U7 Q' N  \
    (setq a (getvar "area") aa (/ a 1000000.0) aa (rtos aa 2 4))0 D* o# l1 U  A" j, H% ]' L
    (setq p1 (getpoint "/n文字位置:  "))
+ q( C! W: b+ ?. m, F( i/ h' b# S# N/ j    (command "text" p1 "200" "0" aa)1 P! s- {$ ?" i
)# N* X9 D! ^) U! R
(setvar "cmdecho" 1)
: I$ [7 w& k1 K; A# ^% Z+ D)
$ {) n, r$ J$ Z  A(defun c:mjw ()
% N' A2 l; ?% @; L' R2 U/ s3 y  (prompt "请输入要求非标面积的层名:  ")( m$ r3 e# D1 W( i" v8 {$ i0 t
  (setq aly (getstring))# f$ v8 N. w$ S
  (command "layer" "s" "0" "f" "*" "t" aly "")/ z2 R: p' ], [$ P" @
  (prompt "选择要标面积的图形: ")
: r+ }& W, [  X0 l9 e  (while (setq ena (ssget ) )* d0 p% T2 N: W1 t, l2 d
  (if (/= ena nil)(setq n (sslength ena) i 0)(setq n 0))# t; E+ k  d- r0 L
  (repeat n
0 ?$ a0 x- l$ J2 d' p7 u  (setvar "clayer" "0")(setvar "cmdecho" 0)3 |! }: E. ~7 |$ o: ^$ t6 g
   (setq en (ssname ena i) ee (entget en) lla (cdr (assoc 8 ee)) i (1+ i))' p6 W0 L" c. V4 L/ Y9 F' l
    (command "list" en "")( i9 W. t& v3 t) t9 ~- j, k
    (command "change" en """p" "la" "0" ""); M! f2 N0 @1 G+ D) B2 p
1 m3 W$ N. D# A    (setq p1 (getpoint "/n文字位置:  "))
+ R' ~1 R4 P" T8 r% A! m    (command "text" p1 "200" "0" aa)
! f! `" }1 M" x! Z9 R: i8 I    (command "change" en """p" "la" lla "")
  l  {) n. b( Q )
0 h/ s, |8 b/ B# i9 `9 _- X) ]" N )6 f0 z% Z! U9 b; T
6 o# Y5 Q1 C1 P, e$ y3 p% O5 c+ A)
发表于 2012-6-7 09:01:50 | 只看该作者
发表于 2012-6-12 11:24:16 | 只看该作者
发表于 2012-6-12 21:17:22 | 只看该作者
发表于 2013-1-18 20:02:29 | 只看该作者
发表于 2013-1-24 19:58:53 | 只看该作者
GMT+8, 2026-8-2 18:11 , Processed in 0.057250 second(s), 11 queries , Gzip On, Redis On.
