查看: 13490|回复: 4
[原创] 请问有谁知道等高加工怎么加密?
发表于 2013-4-12 17:11:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
也就是CONTOUR SHALLOW怎么用?谁能详解一下?
发表于 2013-4-12 17:13:36 | 只看该作者
附图,SHALLOW参数对话框:
发表于 2013-4-12 17:19:15 | 只看该作者
这是英文说明,看不懂。谁懂英文,能翻译下吗?
Setting contour shallow parameters
Mastercam allows you to add to or remove cuts from shallow areas in a rough or finish contour (constant Z) toolpath. You can add or remove full cuts or partial cuts from the shallow areas. You can access the Contour Shallow dialog box where these options are located by choosing the Shallow button on the Rough contour parameters tab or the Finish contour parameters tab.
The minimum stepdown on the Contour Shallow dialog box sets the minimum distance between the added Z cuts in the shallow areas of the part.
The limiting angle sets the angle that defines the shallow areas on the part. A typical limiting angle is 45 degrees. Mastercam adds or removes cuts in an area that ranges from zero (0) to the limiting angle (usually 45 degrees).
The limiting stepover is used as the maximum stepover when removing cuts from shallow areas. If adjacent cuts are further apart than the limiting stepover value, then one of the cuts is removed. Entire cuts are only removed if the whole cut is shallow. You can remove only the shallow part of a cut.
The limiting stepover is used as the minimum stepover when adding cuts to shallow areas. If adjacent cuts are further apart than the limiting stepover value, then additional cuts are created between the adjacent cuts. You can add only the shallow part of a cut.
发表于 2013-4-12 17:22:10 | 只看该作者
或者具体应用该功能的时候,那几个参数应该怎么给值?
给小了费时费力,给大了好像又没有达到加工效果。
发表于 2014-7-28 20:02:32 | 只看该作者
好样的啊。支持
GMT+8, 2026-6-18 04:31 , Processed in 0.057461 second(s), 12 queries , Gzip On, Redis On.
