查看: 13560|回复: 2
[求助] Creo Elements/Direct Model Manager 异常报告
发表于 2014-6-27 09:55:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
时间      : Fri Jun 27 09:11:47 CST 2014
com.osm.automation.jobspooler.NetworkException: 无法连接到  :8899 处的作业后台处理程序。
        at com.osm.automation.jobspooler.JobSpoolerSocketClient.sendRequest(Unknown Source)
        at com.osm.automation.jobspooler.JobSpoolerSocketClient.sendGetRegisteredJobServersRequest(Unknown Source)
        at com.osm.automation.jobspooler.JobSpoolerClient.getRegisteredJobServers(Unknown Source)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at com.osm.automation.jobspooler.JobSpoolerClientFactory$JobSpoolerClientProxy.invoke(Unknown Source)
        at $Proxy0.getRegisteredJobServers(Unknown Source)
        at com.osm.automation.Automation.hasJobServerConfigured(Unknown Source)
        at com.osm.actionmenu.DefaultActionMenuModel.shouldAddTaskAgentActions(Unknown Source)
        at com.osm.actionmenu.DefaultActionMenuModel.initTasksSectionActions(Unknown Source)
        at com.osm.actionmenu.DefaultActionMenuModel.initActions(Unknown Source)
        at com.osm.actionmenu.DefaultActionMenuModel.init(Unknown Source)
        at com.osm.actionmenu.ActionMenuModelFactory.createActionMenuModel(Unknown Source)
        at com.osm.actionmenu.DynamicActionMenu.getActionMenuModel(Unknown Source)
        at com.osm.actionmenu.DynamicActionMenu.setWMObject(Unknown Source)
        at com.osm.biz.WMDBObject.getWMActionMenu(Unknown Source)
        at com.osm.ui.tree.WMTreeNode.getWMActionMenu(Unknown Source)
        at com.osm.ui.tree.WMDefaultEventHandler.handlePopupTrigger(Unknown Source)
        at com.osm.ui.treetable.WMTreeTableRowHeader.handlePopupTrigger(Unknown Source)
        at com.osm.ui.treetable.WMTreeTableRowHeader$TreeTableMouseListener.mouseReleased(Unknown Source)
        at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
        at java.awt.Component.processMouseEvent(Unknown Source)
        at javax.swing.JComponent.processMouseEvent(Unknown Source)
        at java.awt.Component.processEvent(Unknown Source)
        at java.awt.Container.processEvent(Unknown Source)
        at java.awt.Component.dispatchEventImpl(Unknown Source)
        at java.awt.Container.dispatchEventImpl(Unknown Source)
        at java.awt.Component.dispatchEvent(Unknown Source)
        at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
        at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
        at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
        at java.awt.Window.dispatchEventImpl(Unknown Source)
        at java.awt.EventQueue.dispatchEvent(Unknown Source)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
        at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
        at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: java.net.ConnectException: Connection timed out: connect
        at java.net.PlainSocketImpl.socketConnect(Native Method)
        at java.net.PlainSocketImpl.doConnect(Unknown Source)
        at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
        at java.net.PlainSocketImpl.connect(Unknown Source)
        at java.net.SocksSocketImpl.connect(Unknown Source)
        at java.net.Socket.connect(Unknown Source)
        at java.net.Socket.<init>(Unknown Source)
        ... 45 more
请问如何解决这个问题????
该贴已经同步到 pxz8005的微博
发表于 2014-6-27 15:21:47 | 只看该作者
发表于 2014-6-28 16:07:31 | 只看该作者
GMT+8, 2026-7-26 09:01 , Processed in 0.132055 second(s), 12 queries , Gzip On, Redis On.
