查看: 10246|回复: 0
[求助] 学习后编写solidworks插件有点问题?
发表于 2015-4-4 10:43:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本人大学狗,接触SOLIDWORKS没多久,现在被老师逼得硬着头皮搞二次开发,最近碰到一个问题,望各位大神指点一下,再用VB编写DLLsolidworks插件的时候,编译出来的插件不能被运行,下面附上代码:
Implements SWPublished.SwAddin
Dim iSldWorks As SldWorks.SldWorks
Dim iCookie As Long
Private Function SwAddin_ConnectToSW(ByVal ThisSW As Object, ByVal Cookie As Long) As Boolean
Dim bRet   As Boolean
Set iSldWorks = ThisSW
iCookie = Cookie
bRet = iSldWorks.SetAddinCallbackInfo(App.hInstance, Me, iCookie)
bRet = iSldWorks.AddMenu(swDocNONE + swDocPART, "标准件(&L)", 3)
bRet = iSldWorks.AddMenuItem2(swDocNONE + swDocPART, iCookie, "简易的螺栓标准库(&S)@标准件(&L)", -1, "简易螺栓标准库", "ItemUpdate", "弹出简易螺栓标准件窗口")
SwAddin_ConnectToSW = True
End Function
Private Function SwAddin_DisconnectFromSW() As Boolean
Dim bRet As Boolean
bRet = iSldWorks.RemoveMenu(swDocNONE + swDocPART, "标准件(&G)", "")
Set iSldWorks = Nothing
SwAddin_DisconnectFromSW = True
End Function
Public Sub 简易螺栓标准库()
Shell App.Path & "\初步尝试1.0.exe"
MsgBox "选择的菜单为螺栓标准件!"
End Sub
Public Function ItemUpdate() As Long
ItemUpdate = 1
End Function
部件 引用绝对没有问题的!望大神在闲暇之余瞅瞅,谢谢
GMT+8, 2026-8-3 16:44 , Processed in 0.058814 second(s), 15 queries , Gzip On, Redis On.
