查看: 17750|回复: 22
【分享】AutoCAD2005新功能预览
发表于 2004-3-2 21:14:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Introducing AutoCAD 2005
Creating a single drawing as efficiently as possible is important. Delivering a coordinated set of
drawings in a timely manner directly benefits your bottom line. With AutoCAD 2005 software you
can do both. Everyday tools like the table object and tool palettes help you boost productivity,
and the new Sheet Set Manager helps you control content across entire sets of related drawings,
decreasing the risk of errors. Then, in a single view, you can compose and collate sheet sets and
share them with your project team using plots, eTransmit, or DWF[$#8482] files.
With AutoCAD 2005 you can create drawings more efficiently. Day-to-day productivity boosters in
AutoCAD 2005 include
[$#8226] Enhanced tool palette functionality to customize tools for any AutoCAD command or utility
[$#8226] New table objects that help you easily create and modify schedules, parts lists, revision
history, and more
[$#8226] New field functionality that enables you to reference data, such as the current date or
drawing file name, and include it as text in tables, text objects, and block attribute definitions
[$#8226] Background text mask and common drafting symbols available from the mtext editor
[$#8226] Object linking and embedding (OLE) functionality that improves control over the size and plot
quality of OLE objects
[$#8226] Draw order functionality that provides easier access, greater control, and more predictable
results 显示顺序增强
With AutoCAD 2005 you can view and manage entire sets of drawings with ease and efficiency.
Using the new Sheet Set Manager, you can
[$#8226] View and organize drawing sheets in the easy-to-understand tree structure
[$#8226] Import layouts from existing drawings into a sheet set 输入布局
[$#8226] Add new sheets to your sheet set
[$#8226] Open and edit sheets from a sheet set
[$#8226] Lay out your drawing sheets using viewports in paper space
[$#8226] Insert view labels and callouts that link across sheets
[$#8226] Coordinate and update title block information, sheet numbering, sheet names, and detail
labels across an entire sheet set
[$#8226] Apply plot stamp information anywhere on a sheet, ensuring that the plot stamp data is
updated for every plot
[$#8226] Insert a sheet index on the title sheet, which automatically lists all the sheets in the set and
creates hyperlinks
[$#8226] Navigate through a sheet set using hyperlinks
[$#8226] Archive an entire sheet set at the end of the project or at key points along the project
lifecycle
AutoCAD 2005 makes it easy to share individual drawings or entire sheet sets. You can
[$#8226] Select the entire sheet set or a specified set of sheets using named sheet selections
[$#8226] Apply predefined plot settings using named page setups
[$#8226] Plot an entire sheet set or a specified set of sheets in the background while you continue
working
[$#8226] Create an electronic transmittal set of an entire sheet set or a specified set of sheets
[$#8226] Publish a sheet set to a DWF (Design Web Format[$#8482]) file with hyperlinks that provide oneclick
navigation through the sheets
发表于 2004-3-2 21:20:50 | 只看该作者
发表于 2004-3-2 21:21:44 | 只看该作者
发表于 2004-3-2 21:30:33 | 只看该作者
发表于 2004-3-2 21:31:17 | 只看该作者
发表于 2004-3-2 21:31:43 | 只看该作者
发表于 2004-3-9 21:23:51 | 只看该作者
发表于 2004-3-9 21:24:29 | 只看该作者
发表于 2004-3-10 09:16:58 | 只看该作者
发表于 2004-3-14 17:49:19 | 只看该作者
GMT+8, 2026-8-24 08:48 , Processed in 0.059149 second(s), 11 queries , Gzip On, Redis On.
