高级管理(Administration)
5.19 高级管理(Administration) 1:工程图管理(Drawing management) 1)禁止文件新建对话框 (Prevent File > New) 2)禁止更换标准 (Prevent switch of standard) 3)禁止更新标准 (Prevent update of standard) 4)禁止访问背景视图 (Prevent background view access) 2:样式 (Style) 1)使用样式标准创建新对象 (Use style values to create new objects) 2)创建新图纸的参考样式(对于 V5R14 之前的工程图)(Create new sheet from (for pre-V5R14 drawings)) A:选择样式标准(Style ) B:参考第一页图纸的样式(First sheet) 3)锁定“用户默认”样式 (Lock "User Default" Style) 4)禁止“设置为默认”和“重置所有默认值”(Prevent "Set As Default" and "Reset All Defaults") 5)在对话框中显示重置按钮 (Display Reset button in dialog boxes) 3:创成式视图样式 (Generative view style) 1)阻止使用创成式视图样式 (Prevent generative view style usage) 4:修饰 (Dress-up) 1)禁止尺寸驱动 3D 约束 (Prevent dimensions from driving 3D constraints) |
GMT+8, 2026-8-14 03:15 , Processed in 0.042588 second(s), 11 queries , Gzip On, Redis On.
