B09-整合场协同理论和模流分析探讨含玻纤塑料于指叉状波浪流道之流动行为
2011-8-16 16:53| 查看: 50754| 评论: 0|原作者: 张旭铭、杨耀升、郑志清、陈宏宾萧乃仁|来自: 科盛科技
摘要: 本研究 以质子交 换 膜料燃电池 (Fuel cell) 之双极板 为例 , 研究中 以材 料 PA6( Polyamide, Nylon6 )TECHNYL C217 Rhodia 和 PA6( Polyamide, Nylon6 )TECHNYL C218 V40 Rhodia(含 40%玻纤),使 用场协 ...
五、结果与讨论
未含玻纤与含玻纤之双极板在充填时有均未产生包封产生,配向值越高代表纤维被流场在该方向 配向的程度越高,纤维配向程度,指叉状波浪流道50.755%,含玻纤时因热传较好,平均场协同角较 小。由仿真结果显示,利用场协同角、玻纤与流道形状配合模流软件可用来找出较佳的组合,来微 调流动平衡,提高燃料电池双极板具纤维配向射出成型过程的效率,配合场协同角与燃料电 池双极板玻纤配向与玻纤比率可提供日后研究的重点。
六、参考文献
1.Shiuh Ming Chang,Hung Pin Chen,"Indoor Thermal Comfort Optimization by Field Synergy Principle for Air-Conditioning", International Journal of Intelligent Systems and Applications (IJISA),Volume 3, Number 1( publishing)
2.Shiuh Ming Chang*、Jie Hao Chang、Jiun Hau Huang, “Optimization Cooling Fan Position for CPU byField Synergy Principle”,Journal of Professional Mechanical Engineers, 2010, Vol.3, No.3, pp.1-7,
3.Shiuh Ming Chang*、Jia Fu Lee、Chih Hua Hsu、Cai Wan Chang-Jian,” Auto Mode IC Mold Flow byUniform Filling Principle“,Journal of Professional Mechanical Engineers, 2010, Vol.3, No.3, pp.14-18
4.Shiuh-Ming Chang*, Cai-Wan Chang-Jian ,” Influence on Pem Fuel Cell Bipolar Plate by Different Fiber Orientation and Cooling System”, 2010 International Symposium on Computer, Communication, Control and Automation, IEEE 2010, 3CA,2010, May 5-7, 2010, Taiwan, Tainan ,Vol II, , pp5-8(EI)
5.Shiuh-Ming Chang*, Jenn-Kun Kuo ,” Field Synergy Principle to Square and Trapezoid Types Fuel Cell Bipolar Plate of Mold Injection”, 2010 Asia-Pacific Power and Energy Engineering Conference (APPEEC 2010), IEEE 2010, March 27-31, China, Crowne Plaza Chengdu, Paper ID:91254, 03-083, pp1-6 (EI)
6.M. S. Wilson and D. N. Busick, “Composite Bipolar Plate for Electrochemical Cells”, WO00/25372. (2000)
7.M.  K.  Bisaria,  A.  Peter,  A.  Mohamed,  C.  Yuqi,  “Injection  Moldable  Conductive  Aromatic Thermoplastic Liquid Crystalline Polymer Compositions”, WO00/44005. (2000)
8.R. Horung and G. Kappelt, “Bipolar Plate Materials DevelOPMent Using Fe-based Alloys for Solid Polymer Fuel Cells”, Journal of Power Sources, Vol 72, pp. 20-21.(1998)
9.J. Wind, R. Spah, W. Kaiser and G. Bohm, “Metallic Bipolar Plates for PEM Fuel Cells”, Journal of Power Sources, Vol. 105, pp. 256-260. (2002)
10.D.P. Davies, P.L. Adcock, M. Turpin and S.J. Rowen, “Bipolar Plate Materials for Solid Polymer Fuel Cells”, Journal of Applied Electrochemistry, Vol. 86, pp.237-242. (2000)
11.R.  C.  Makkus,  A.  H.H.  Janssen,  F.  A.  de  Bruijn  and  R.  K.A.M.  Mallant,  “StainlessSteel  for Cost-competitive Bipolar Plates in PEMFCs”, Fuel Cells Bulletin, Vol. 3, pp.5-9. (2000)
12.Http://H2economy.com,Website. (2002)
13.F. Mighri, M. A. Hunealt, and M. F. Champage, “Electrically Conductive Thermoplastic Blends for Injection and Compression Molding of Bipolar Plates in the Fuel Cell Application”, Polymer Engineering and Science, Vol. 44, pp. 1755-1765. (2004)
14.A. Heinzel, F. Mahlendorf, O. Niemzig and C. Kreuz, “Injection Moulded Low CostBipolar Plates for PEM Fuel Cells”, Journal of Power Sources, Vol. 131, pp.35-40.(2004)
15.10. R. H. J. Blunk, D. J. Lisi, Y. E. Yoo and C. L. TuckerIII, “Enhanced Conductivity of Fuel Cell Plates through Controlled Fiber Orientation”, AIChE Journal, Vol.49, pp.18-29. (2003)
论文下载:
1234567
